Re: C.L.E.A.N. Engine Bay (hidden wires & components)
[Re: WyleECoyote]
#1680161
10/02/14 01:29 PM
10/02/14 01:29 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
I don't have any pics of it but I did a mustang a while back and I took all of the wiring to the engine and put adel clamps on the oil pan bolts and ran all of the wiring to the front of the engine along the pan and then up the front of the engine. Was really clean and you could still get to it if you had to check something. Head light wiring I would run through the frame rails to the front.
Back in the swing of things at Painless again! Great to be back!
[Re: cogen80]
#1680163
10/02/14 07:22 PM
10/02/14 07:22 PM
Posts: 12,408 Taxes & Virus's R-US, NY
Dragula
lack of wires look great.... BUT... IMHO all the holes that were not filled take away from the look big time. the top of the shocks being painted looks bad, same with the upper control arm cam bolts and master cyl mounting plate being painted green. they all take away from what could be a really good looking engine compartment.
They are coil overs not shocks...And as an original 440+6 shaker hood 4 speed car with only 13k miles on it, I left the holes figuring whomever was well off enough to afford to buy it some day will most likely switch it back to stock. Not to mention at the time I painted it, I did not have a mig welder to do that. Maybe I should leave the under coating on next time too.
If I were to do it my way. it wouldn't even have inner fenders or a stock firewall. This seemed to be the best compromise between what I wanted and keeping some value to it. Besides, nobody notices the engine bay with that thing in there....If I repaint it this winter when I pull the engine, who knows...
[Re: Dragula]
#1680165
10/02/14 10:09 PM
10/02/14 10:09 PM
Posts: 9,865 MI, usa
dvw
MI, usa
This work for you?
Very nice. People are complaining but overall very well done. Nice detail on the engine itself, way better than most. Paint on the bolts is a quick cheap fix compared to the quality of the rest. Doug
