Will a 440 H-Pipe factory exhaust system fit a 383? #1679871
09/29/14 02:38 PM
09/29/14 02:38 PM
Arizona
69rrgrabber Offline OP
Arizona
Hello!
Looking at all options for and exhaust system for my 69 383 road runner. Its a toss up between headers and manifolds but Im leaning towards the manifolds since the rest is all stock. I'd really like an H pipe and wonder if the factory style 440 set up would work?
Thanks,
Carl
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: Will a 440 H-Pipe factory exhaust system fit a 383? [Re: 69rrgrabber] #1679872
09/29/14 02:48 PM
09/29/14 02:48 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Check out TTI Exhaust. I put the 2-1/2" manifold back H pipe system on my 383 SuperBee and it fit great out of the box.
Re: Will a 440 H-Pipe factory exhaust system fit a 383? [Re: 69rrgrabber] #1679873
09/29/14 02:51 PM
09/29/14 02:51 PM
California
1970mopar Offline
1970mopar  Offline
California
no
Re: Will a 440 H-Pipe factory exhaust system fit a 383? [Re: 69rrgrabber] #1679874
09/29/14 03:25 PM
09/29/14 03:25 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Hello!
Thanks,
Carl
The 440 is an RB block so the pipe will be too tall for the 383.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Will a 440 H-Pipe factory exhaust system fit a 383? [Re: MOPARMIKE69] #1679875
09/29/14 04:07 PM
09/29/14 04:07 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Thanks,
Carl
Re: Will a 440 H-Pipe factory exhaust system fit a 383? [Re: MOPARMIKE69] #1679876
09/29/14 04:14 PM
09/29/14 04:14 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Hello!
Thanks,
Carl
The height won't be as bad as the WIDTH you will end up with once the 2 pipes are stuck together.
A TRUE factory style H pipe is ONE PIECE so they will be wider than the outlet placement on a 383 .
Re: Will a 440 H-Pipe factory exhaust system fit a 383? [Re: 69rrgrabber] #1679877
09/29/14 04:24 PM
09/29/14 04:24 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Have an exhaust shop fab-up a system in something you'll get some longevity out of(stainless, or aluminized)...
Then, it's either balance-tube, or X...
Re: Will a 440 H-Pipe factory exhaust system fit a 383? [Re: RSNOMO] #1679878
09/29/14 11:38 PM
09/29/14 11:38 PM
Roseburg, Oregon
Tom Swope Offline
Tom Swope  Offline
Roseburg, Oregon
Yes a 440 h-pipe will fit a 383 if you do the following. Spring the two pipes together 1" between the flanges. Remove the starter and install the h-pipe. Re-install the starter and you are done.
Here is a link that will explain how to spring the h-pipe together.
http://www.accurateltd.com/H-Pipe-Info_ep_33.html
