Pistol grip shifting issue
#1679696
09/29/14 03:43 AM
09/29/14 03:43 AM
Posts: 247 I DA HOE
3406pac
I DA HOE
Having a issue with the shifter hitting the console in my e body. This happens in 2nd. And 4th gear. Also it is very tight to shift. Is this a linkage adjustment, or will rebuilding the shifter be the fix? The console was moved all the way back but still hits, it seems like the throw is too long, along with the tightness issue. Any help is appreciated. Thanks
AAR cuda
71 rag challenger
Re: Pistol grip shifting issue
[Re: JohnRR]
#1679698
09/29/14 01:48 PM
09/29/14 01:48 PM
Posts: 6,018 Salem
Grizzly
Moparts Proctologist
Salem
That can be a worn transmission mount. It drops the transmission a bit lower and pulls the shifter with it. It don't take much. ![](/ubbthreads/images/graemlins/Twocents.gif)
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#1679699
09/29/14 05:18 PM
09/29/14 05:18 PM
Posts: 247 I DA HOE
3406pac
I DA HOE
The shifter has room on the forward position.
I wouldn't see how the tranny mount would cause this, do you mean the shifter mount to the tranny?
Can the rods be interchanged and make it shift like this? Would that also cause the stiff shifting?
AAR cuda
71 rag challenger
[Re: 3406pac]
#1679700
09/29/14 06:01 PM
09/29/14 06:01 PM
Check the shifter mounting plate for movement. It's the diamond-shaped plate that mounts to your transmission, and your shifter mounts to it. The bolts on mine worked their way loose once and my shifter hit the console in 2nd and 4th.
[Re: 3406pac]
#1679701
09/29/14 06:03 PM
09/29/14 06:03 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
No the rods can't be interchanged .
Is this an original 4 speed , and original console car ? where in the hole in the floor does the shifter come up?
what's the history of the shifter ?
[Re: JohnRR]
#1679702
09/29/14 06:31 PM
09/29/14 06:31 PM
Posts: 247 I DA HOE
3406pac
I DA HOE
It is the original shifter and console, car was sitting for 30 years, so shifter could be questionable. I am not sure where the shifter is sitting, in the hole, other then at the shop with no one to take the time to troubleshoot it properly. So all suggestions I will have to forward to them.
I will have them look at the mounting to make sure it is right. Thanks
AAR cuda
71 rag challenger
[Re: 3406pac]
#1679704
09/30/14 12:30 AM
09/30/14 12:30 AM
Posts: 6,018 Salem
Grizzly
Salem
[quoteI wouldn't see how the tranny mount would cause this, do you mean the shifter mount to the tranny? Sorry about that, I'll explain it a little better: It's the transmission to crossmember mount you are looking at. After they take years of supporting all that weight hitting every bump in the road, the rubber pounds and mushes out. It only takes a fraction of an inch at the mount to make a big difference up top at the shifter. You can have a helper go under there with prybar and pry up on the transmission while you watch from in the car and see how much difference it makes. Would that also cause the stiff shifting? The grease in your shifter is all dried up and full of dirt.
It's a tedious job, but just pull the whole Hurst mechanism apart, clean it, grease it all, and put it back together. Take lots of pictures while you are doing it and try to stack everything in the order it came apart. I've done it, it's a piece of cake. Made a huge difference.
That must be the reason why the later shifters have a grease nipple on them.
Mo' Farts
[Re: Mr D21]
#1679706
10/01/14 04:18 PM
10/01/14 04:18 PM
Posts: 247 I DA HOE
3406pac
I DA HOE
Are there parts that usually require replacing when I tear this down? Or just clean it up and rebuild. Also what finish if I choose to replate.
AAR cuda
71 rag challenger
[Re: 3406pac]
#1679707
10/01/14 07:20 PM
10/01/14 07:20 PM
Posts: 4,285 Ohio
64dodge572
Ohio
These are the typical wear parts: http://www.brewersperformance.com/proddetail.asp?prod=H0001 If you don't need it all we sell individual parts also.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
