UPDATE#2:
Found the problem. Internal short with the stock AM/FM radio. Internally the radio light is grounded. It's not worth the trouble to pull the radio and tear it apart to replace a stupid light. I never use it anyway. At least I've got my gauges back and everything else seems to work well. Interesting problem, huh?
Does anyone out there have the internal layout of the headlight switch for a 71 B-body. I'm having a problem with no power to the instrument panel lights and I think it might be in the switch. Replacing the switch is a HUGH undertaking and I'd like to be more sure that the problem is in the switch before tearing apart the instrument panel to get to it(you know, lowering the steering column, removing the A/C control, radio, console, etc.)
