Re: LCA poly bushings walking out of the shell when install [Re: Lefty] #1677984
11/07/14 12:29 PM
11/07/14 12:29 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I manufacture a Delrin bushing that does not use the original outer shell.
If the torsion bars are installed all the way forward AND adjustable strut rods are used, they won't move.
My opinion on OE bushings are they were junk when new and are worse now due to offshore manufacturing. I see these blown apart on a regular basis even with limited usage.
Stabilizing the lower arm and strut rod are so important in creating a tight suspension, but it takes the purchase of some pricey parts.
Re: LCA poly bushings walking out of the shell when install [Re: BergmanAutoCraft] #1677985
12/02/14 02:35 PM
12/02/14 02:35 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Could you give us some examples??
I have the PST urethane LCA bushings with all stock components in my 67 coronet. Have always had a clunk in reverse, predominantly the right side ( passenger side).
Are you saying I would need adjustable strut rods to eliminate this using Urethane bushings?
