electric fuel pump location for 74 swinger #1677716
09/27/14 05:57 PM
09/27/14 05:57 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
Hello, i am looking for a location for my electric fuel pump and was wondering if the location behind the spare tire on the lower valance? would be a good spot. seems like it would be to me. any one disagree or have a better spot?
Ryan
Re: electric fuel pump location for 74 swinger [Re: ryanf] #1677717
09/27/14 05:57 PM
09/27/14 05:57 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
where the tape is
Re: electric fuel pump location for 74 swinger [Re: ryanf] #1677718
09/27/14 06:50 PM
09/27/14 06:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You want it as close to the tank as possible. Best bet is up against the frame on the side the fuel line runs. What brand and output is that pump. It looks a bit small to me.
Re: electric fuel pump location for 74 swinger [Re: stumpy] #1677719
09/27/14 06:53 PM
09/27/14 06:53 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
and if it's on sheet metal you might get a lot of extra noise.
Re: electric fuel pump location for 74 swinger [Re: mikemee1331] #1677720
09/27/14 07:00 PM
09/27/14 07:00 PM
spokane/pullman Wa
ryanf Offline OP
ryanf  Offline OP
spokane/pullman Wa
its a walbro GSL-392 (output is 255 lph) i was planning on using some of those rubber isolation mounts to reduce the noise. i was looking at the frame rail just seemed alittle to close to the exhaust. I'm probably just being paranoid though.
Re: electric fuel pump location for 74 swinger [Re: ryanf] #1677721
09/27/14 07:06 PM
09/27/14 07:06 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I made the mistake of mounting my carter pump on the back side of the trunk floor in my Road Runner. all the rubber isolators in the world doesn't help it. it's moving to the frame rail when I finally get my new sending unit...
Re: electric fuel pump location for 74 swinger [Re: ryanf] #1677722
09/27/14 07:42 PM
09/27/14 07:42 PM
Pennsylvania
Red 79 Offline
Red 79  Offline
Pennsylvania
Think my major concern with your location would be if you get rear ended, it would be a prime source for disaster.
Re: electric fuel pump location for 74 swinger [Re: ryanf] #1677723
09/27/14 11:14 PM
09/27/14 11:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
normally on an A or B body, the frame rail near the front spring perch is best, It's somewhat protected and below the tank for gravity feed which most electric pumps like ???
Re: electric fuel pump location for 74 swinger [Re: TJP] #1677724
09/27/14 11:32 PM
09/27/14 11:32 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
On my A-Body I mounted the pump and filter just on the other side of that - I mounted both to the rear of the spare tire well - has a little better protection and I had no issues with fuel delivery or fuel pickup from the stock sender location
Re: electric fuel pump location for 74 swinger [Re: SSAAHemiFan] #1677725
09/29/14 02:37 PM
09/29/14 02:37 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
That pump is not going to be happy pulling. It needs to be low and close to the bottom of the tank.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
