Re: 4 speed with power disk brakes? HELP
[Re: R/T1968R/T]
#1677653
09/27/14 04:24 PM
09/27/14 04:24 PM
Posts: 452 new york usa
pattyboy 572
new york usa
Yes they did. I Have a 1970 RR with a/c and 4 speed ,went thru like 3 boosters till I purchased the correct one from pirate- jack .the (ram man) also has the correct one... you will go crazy to find the correct rod length .. keep in mind you still may have to move the brake light switch to the other mounting holes that should be on the bracket as well...just saying just completed my resto may 2014
[Re: pattyboy 572]
#1677654
09/27/14 07:23 PM
09/27/14 07:23 PM
Posts: 643 southern conn
1969gtx
southern conn
If you are going from non power brake to power brakes.The peddle is now lower an you need to move the brake light switch look up at the switch whereit bolts theres two holes it can fit to. The brake peddle will be around 2" lower then the clutch peddle
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: pattyboy 572]
#1677656
09/30/14 11:55 AM
09/30/14 11:55 AM
Posts: 1,348 VA
dragon slayer
VA
What rod code was it that worked, 8BD?
[Re: dragon slayer]
#1677657
09/30/14 12:36 PM
09/30/14 12:36 PM
pattyboy 572
new york usa
Don't know the rod code ,purchased the whole booster from pirate -jack ,ram man explained to me the rods were not serviceable , that the whole booster needed to be disassembled to change the rod to the correct one.so I purchase a new booster cheaper than a rod change. I had the original booster to the car ,I was missing the rod (after 3 body shops )the rod was lost .pat (call Wayne at the ram man he will explain the whole thing about the rods)..
[Re: John_Kunkel]
#1677658
09/30/14 05:19 PM
09/30/14 05:19 PM
Posts: 821 NW Ohio
6pkaar
NW Ohio
Brake pedal is lower with P/B and standard trans, with auto both pedals are at same height.
Is this the same with '70 E-body?
