Re: Internal Balance with Cast crankshaft?
[Re: ChevyTS]
#1677238
09/27/14 03:44 AM
09/27/14 03:44 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I built a cast crank 451 in 2006 and it had 440 source H beams and Ross pistons and I didnt turn down the counterweights on the crank, I ground the block for clearance. It internal balanced very easily with no mallory metal. The engine is still running fine today in my Challenger.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: ChevyTS]
#1677241
09/29/14 10:19 PM
09/29/14 10:19 PM
HemiRick
Memphis
or to ask this question in reverse form, what is amount of the offset weight on the damper and flexplate?
[Re: HemiRick]
#1677242
09/30/14 02:27 AM
09/30/14 02:27 AM
Posts: 1,025 Las Vegas, NV
dodgeboy11
Las Vegas, NV
That's the answer to the question. How much weight and how far from center is it placed? I think it's worth having heavy metal added. This doesn't help, but the balancer for six pack engines has a 6.5 oz imbalance.
[Re: AndyF]
#1677246
10/01/14 11:55 PM
10/01/14 11:55 PM
Posts: 576 Texas
ChevyTS
Texas
You should be able to get a cast crank 440 to balance internally as long as you use lighter weight forged pistons. Aftermarket rods would also help the situation. I think the cast crank will balance at about 2500 gram bobweight but it has been a few years since I did this exercise.
Thanks for the in put I will give it a try and see.
