Re: Reman Engine - +0.020" with stock pistons?
[Re: Challenger 1]
#1677143
09/26/14 10:36 AM
09/26/14 10:36 AM
Posts: 1,567 Ky
jt4406
Ky
Found 3 pistons, in a set of 8 .030 over size replacements, that were standard size. Even better, they were stamped .030 on the top, just like the other 5 in the set. Box packed early Monday, or late Friday?? ![](/ubbthreads/images/graemlins/shruggy.gif) Anyway, Gary is right, wwaaaayyyyy too much piston to cylinder wall clearance. ![](/ubbthreads/images/graemlins/Twocents.gif) jess
Yeah, it's hopped up to over 160...
[Re: jt4406]
#1677144
09/26/14 11:20 AM
09/26/14 11:20 AM
Posts: 10,773 North Dakota
6PakBee
North Dakota
Sounds to me like that engine has been apart before. A standard piston in a 0.020 over hole rattles around like a baseball bat in a garbage can. Unless someone was totally incompetent, that would have been picked up on initial assembly.
[Re: GoodysGotaCuda]
#1677145
09/26/14 11:30 AM
09/26/14 11:30 AM
Posts: 28,078 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
If he picked it up from the reman company I'd go back and drop it off again.
If it came from an individual, he needs to order some new pistons and rings.
#1677146
09/26/14 11:50 AM
09/26/14 11:50 AM
Posts: 12,320 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Has the engine been run like that?
It certainly won't last long that way.
Master, again and still
[Re: mopar346]
#1677148
09/26/14 12:36 PM
09/26/14 12:36 PM
RapidRobert
What 346 said, time to do some precision measureing. EDIT you can use rings that are up to .010" larger than the bore/piston dimention (file fit for correct gap as needed of course) but a 20 over ring will give an oval ring shape (even if filed down for the correct end gap) & wont seal correctly
