Re: 1973 D200, stock tire size?
[Re: Exit1965]
#1676635
09/25/14 01:07 AM
09/25/14 01:07 AM
Posts: 5,302 CA, Proprietor; The "PALOMINO"...
dynotune440
7.50x16.5 tires... 9.50x16.5 optional All 4 same unless spec'd for traction tread rear tires. Most would do bigger rear tire for camper back in the day....
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
[Re: 76dodgeboy]
#1676639
09/28/14 12:22 AM
09/28/14 12:22 AM
dynotune440
Says in your door jamb on the cab.
Too old, they started that in 77, 78 for sure...
[Re: dynotune440]
#1676640
09/28/14 08:51 AM
09/28/14 08:51 AM
Posts: 37 Germany, Berlin
muskote
Germany, Berlin
At the early ones it should be listed on the hood tag..., if it´s still there. You´ll find it also on the "Building Order" sheet, if you´re happy to find it. (under/behind seat, behind door panels, under dash... Here´s an example of my 73 D100... Inside Hood Door Post Pillar Building Order
