98 T&C rack/pinion leak #1676539
09/24/14 11:48 AM
09/24/14 11:48 AM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
On a 1998 T&C rack that is leaking from the lower metal line supplying the rack ( not a ps hose), is there any other fix than replacing the rack assembly? Thanks
Re: 98 T&C rack/pinion leak [Re: BH27G1B] #1676540
09/24/14 12:30 PM
09/24/14 12:30 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Lucas P/S stop leak if there is a o ring or gasket in that spot.
Re: 98 T&C rack/pinion leak [Re: ademon] #1676541
09/24/14 12:42 PM
09/24/14 12:42 PM
MA
BH27G1B Offline OP
BH27G1B  Offline OP
MA
The leak is coming from the line right where it threads into the steering gear. I think the line is porous there. Are those metal lines replacable?
Re: 98 T&C rack/pinion leak [Re: BH27G1B] #1676542
09/24/14 02:29 PM
09/24/14 02:29 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Nope
