273 commando valve clearance problem #1676413
09/24/14 09:41 AM
09/24/14 09:41 AM
western australia
1cuda Offline OP
1cuda  Offline OP
western australia
i`m building a 273 commando for a 65 signet-it`s a restoration so that`s why the 273. i had stainless 1.88 and 1.6 valves put into the heads and now i`ve got valves that hit the cylinder walls-has anyone come across this before? i thought i did my homework and people on forums said only the 2.02 valves would need cylinder fly cut but after mocking up a head on a empty bore i can see the valve hits at .250 open-mainly the exhaust one.
my question-it`s going to run a 470 lift cam- how far down can i cut the relief? pistons are 10.5 egge and they are .082 down the hole.
they have about .200 of land above the top ring.
how close can the relief be to that top ring?
any help really appreciated.
all the best
frank.
Re: 273 commando valve clearance problem [Re: 1cuda] #1676414
09/24/14 11:25 AM
09/24/14 11:25 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I notched a 273 once for 1.92 valve Magnum heads. I just masked it off took a carbide in the die grinder and beveled off the edge.
Worked fine. I used a coffee filter in the cylinder to catch the shavings.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: 273 commando valve clearance problem [Re: 1cuda] #1676415
10/03/14 11:49 AM
10/03/14 11:49 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
all the best
frank.
You can also cut down a 1.88 to 1.84 and you won't have the shrouding problem.
Re: 273 commando valve clearance problem [Re: dart4forte] #1676416
10/06/14 04:19 PM
10/06/14 04:19 PM
dogdays Offline
dogdays  Offline
If you don't cut past the valve seat line...
R.
