93' 5.9 Magnum fuel pressure issue #1676072
09/23/14 10:00 AM
09/23/14 10:00 AM
Upstate, NY
MikeP Offline OP
MikeP  Offline OP
Upstate, NY
Hi all !
1993 W250 5.9L Magnum.
Was running rough, stumbles at idle, dogs out/back fires with any throttle. New I had a burnt plug wire.
Did plugs, wire cap rotor. No improvement.
Was messing with timing and decided to squirt a little gas into
throttle plates and the engine smoothed right out.
Couldn't hear the fuel pump come on plus the filter is on the pump
in the tank, so I put a new pump and filter in. No improvement.
I had fuel at the shrader valve on the rail. Went to Rock Auto under fuel and they listed a Fuel pressure regulator. There isn't one on this truck at the rail, Only SS braided line from hard line on frame to fuel rail. I disconnected it and had a piece of clear hose same diameter as male line inserted in to SS quick connect and turned on key. Plenty of fuel volume for 2 secs until the relay shuts it off.
Put a guage on line and cycled the pump a couple times with key and could only get ~10 psi. During my troubleshoot I suspected voltage to pump, Ran a meter on line in and with truck running had 14.0 V.
Cleaned all grounds.
1) What should the Psi be ? ~ 40psi?
2) Should I measure psi at Shrader vale on rail?(dont' have an adapter)Can I pull valve out like a tire shrader vale and plumb to guage?
3) Could it be plugged injector(s) ? Should I replace all of them?
Any advice appreciated !
"Think Pink" 67'Dart GT vert, 69' Newport vert, 67' Barracuda and a pile of trucks 78'79'91'92 CTD
Re: 93' 5.9 Magnum fuel pressure issue [Re: MikeP] #1676073
09/23/14 01:36 PM
09/23/14 01:36 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Pressure should 40 psi at 2000rpm. Did you install an airtex pump? There have been a number of failures of the brand. Pressure regulator is part of the pump on your truck I think.
Re: 93' 5.9 Magnum fuel pressure issue [Re: stumpy] #1676074
09/23/14 10:21 PM
09/23/14 10:21 PM
Upstate, NY
MikeP Offline OP
MikeP  Offline OP
Upstate, NY
Yes, Psi regulator is part of pump
Bought the pump thru Napa, don't remember brand.
Put a guage on port exiting pump and had 18 psi
Had 14 volts on pump while running yesterday.
Should I unplug it and hot wire 12v and ground
and restest?
Can't believe old pump and new pump are the issue.
But I swear I remember hearing the pump pressure up when
key was on before the issue, now I don't hear it.
Thanks Stumpy !
Re: 93' 5.9 Magnum fuel pressure issue [Re: MikeP] #1676075
09/24/14 01:28 AM
09/24/14 01:28 AM
Grand Prairie,Texas
Grand Prairie,Texas
Sounds like a bad pump. Lowering the voltage isn't going to make it pump more pressure.
Re: 93' 5.9 Magnum fuel pressure issue [Re: stumpy] #1676076
09/24/14 06:40 AM
09/24/14 06:40 AM
Upstate, NY
MikeP Offline OP
MikeP  Offline OP
Upstate, NY
My point was to hot wire it directly off the Battery directly with +12V and with battery ground to eliminate a short.
(had 14v with truck running)
Re: 93' 5.9 Magnum fuel pressure issue [Re: MikeP] #1676077
09/24/14 07:41 AM
09/24/14 07:41 AM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
No reason to. You already know it has full voltage. As long as it has a good ground, which you said you checked, it should be putting out full pressure.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 93' 5.9 Magnum fuel pressure issue [Re: GTSDart340] #1676078
09/24/14 07:53 AM
09/24/14 07:53 AM
Upstate, NY
MikeP Offline OP
MikeP  Offline OP
Upstate, NY
Just came in from shop
Old pump puts out 40 psi on the Bench
Jumped the new pump in the tank and had 50psi.
So even though I had 14v, I'm missing some amps.
I'm guessing ground, I cleaned all terminals in relay
that could be it too)
Least I know its electrical.
Option 1. Run new ground and retest thru relay
Option 2 If No go, run new 12V wire from relay
Option 3 it's bad contacts in relay
Anything I missed?
Thanks !
Re: 93' 5.9 Magnum fuel pressure issue [Re: MikeP] #1676079
09/24/14 08:46 AM
09/24/14 08:46 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Fuel pump relay?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 93' 5.9 Magnum fuel pressure issue [Re: 3hundred] #1676080
09/24/14 09:32 PM
09/24/14 09:32 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
92-93 magnums had the regulator on the fuel rail. In 94, they went to single line feed with the regulator in the fuel pump module.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 93' 5.9 Magnum fuel pressure issue [Re: 71yelladustr] #1676081
09/24/14 09:45 PM
09/24/14 09:45 PM
ky.
K
kenworth_goose Offline
K
ky.
I thought the filters were on the frame still on the 93's? that would be the first thing i'd change.
Re: 93' 5.9 Magnum fuel pressure issue [Re: kenworth_goose] #1676082
09/24/14 10:02 PM
09/24/14 10:02 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
True on the 318's, for whatever reason the 360's had it with the pump.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: 93' 5.9 Magnum fuel pressure issue [Re: 71yelladustr] #1676083
09/25/14 01:12 AM
09/25/14 01:12 AM
CA, Proprietor; The "PALOMINO"...
dynotune440 Offline
dynotune440  Offline
93 magnums were weird... 5.2 mag had an inline fuel filter and a return fuel line with regulator in fuel rail.
5.9 mag had no inline filter, returnless fuel rail, and fuel regulator in fuel pump module assembly...
Bought a few of these trucks for cheap because of a bad pump...
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: 93' 5.9 Magnum fuel pressure issue [Re: dynotune440] #1676084
09/25/14 09:49 AM
09/25/14 09:49 AM
Upstate, NY
MikeP Offline OP
MikeP  Offline OP
Upstate, NY
Started with a fuel pump relay, wouldn't plug in....back to Napa.
No Fuel psi regulator on rail.
Will update when I have fixed, by the wkend.
Appreciate the replys !
Re: 93' 5.9 Magnum fuel pressure issue SOLVED [Re: MikeP] #1676085
09/27/14 09:13 AM
09/27/14 09:13 AM
Upstate, NY
MikeP Offline OP
MikeP  Offline OP
Upstate, NY
It was the ground. Siamesed splice right at pump plug then to Body.
New pump has 50 psi.
Thank you !
