Re: Roadracers and AutoXer's, which wheels ?
[Re: OzHemi]
#167606
12/15/08 04:13 PM
12/15/08 04:13 PM
Posts: 173 Tucson AZ
2cudabuck
Tucson AZ
Kiesler has those new rims built for our older cars that are Viper SRT replica's. Don't know about weight etc, but I do know that they are engineered for our E and B bodies.
Buck
67 273 Dart GT
69 RT 440 Charger (SWEET!)
70 318 Cuda
74 Cuda Packin a 426 roller Hemi
[Re: 2cudabuck]
#167607
12/15/08 04:44 PM
12/15/08 04:44 PM
Posts: 3,577 Long Island, NY USA
BergmanAutoCraft
Long Island, NY USA
Lots of rims out there. True, Fikse, Forgeline, HRE are all top stuff, but probably more $$ than may would want to spend. There are many other good wheels our there that are less money like Boze, Intro etc. Many 2 and three piece wheels to choose from. Look for aircraft hardware, 6061 hoops, etc. As far as the Ford stuff goes, I think its all cast alum. I have been using the Chinese copies and have had zero troubles over the course of a couple years now. Against the judgement of many on the board, I would stay away from 17s because the choices are limited. 18s offer the best selection of tires in the closest heights that fit the older cars, with an excellent selection of compounds.
[Re: 2cudabuck]
#167608
12/15/08 04:46 PM
12/15/08 04:46 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
realistically, I'd be looking at stiffness of a wheel more than weight.
If you're not made of money, and trying to be weight conscious on unsprung weight, I'd look at relative weights of tires more than wheels-- there can be a 5lb variance between different tire brands in the same size, and that weight is probably mainly in the tread, which is much further away from the neutral axis, increasing your moment of interia. higher MoI will require more power to accelerate.
Comparing a light wheel vs. a heavy wheel of the same diameter, I'd wager a large portion of the weight difference is in the spokes, not in the outer rim. this additional weight is much closer to the neutral axis, so it has a marginal impact on MoI. also, the heavier wheel will most likely be stiffer. a friend has seen "lightweight" wheels flex causing up to 1-2 degrees change in camber on cars with on-board telemetry in autocrossing. the camber change will probably have a greater (negative) impact on handling and consistency than the added unsprung weight.
