Installing Sub-Frame Connectors w/o suspension
#1675848
09/22/14 08:16 PM
09/22/14 08:16 PM
Posts: 77 South
Squirrel_Cat
South
I have an e-body on casters right now, the front is supported at the bumper mounts, no engine and the rear is supported at the front spring mounts. I would like to install sub-frame connectors on the car, weld-in. What is your preferred method for squaring up the car as much as possible? A given right off the bat is that I cannot assume my garage floor is flat, from there my casters can be at slightly different heights. My original thought was to just try to use a level in various places that "should be" parallel with the ground, but that won't be the easiest thing to do either but it would be better than nothing. I'm trying not to induce twist into the chassis, so I am interested in hearing various methods on installing sub-frame connectors.
1973 340 'Cuda
2013 Mustang GT
Re: Installing Sub-Frame Connectors w/o suspension
[Re: Stanton]
#1675852
09/23/14 02:08 PM
09/23/14 02:08 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
If it were me, I'd re-support it by using some wood blocks at the rear K frame bolts, and by spanning from the front of each rear rail and te rear of each rail. You want to do your best to get the weight as it normally would be with the car on the ground. Unibodies do flex like mad, even with no real load on them. By suspending it at the front of the front rails, and the front of the rear rails, you induce some bend into the cabin and engine bay. Might make it harder later to line up the doors and nose if you weld it that way.
[Re: Squirrel_Cat]
#1675853
09/23/14 05:22 PM
09/23/14 05:22 PM
Challenger 1
Cincinnati, Ohio
I would make sure the doors are mounted and adjusted properly, then I would install them. I did a set on a E body that was just a shell with the car mounted on a rotisserie. I just turned the car sideways and welded them in along with 4 torque boxes. There was no warp age or other problems as everything fit perfect when I put it back together. Just as long as the doors fit, that's all I worried about and the car came out great!. I welded them in when the car was in this position. It was really easy like this, took only an hour or two for all four boxes and the frame connectors. First I blasted the bottom clean, then welded and then blasted the boxes and connectors a second time to insure good paint adhesion. All in my driveway at home.
