Got a Bronze Hardtop or Coupe with saddle interior? #1675737
09/22/14 04:18 PM
09/22/14 04:18 PM
Arizona
69rrgrabber Offline OP
Arizona
Hello,
Trying to figure out the color of the front headliner trim and posts in my 69 T3 road runner with the saddle and T9 interior. Been looking at many pics but have had no luck. SHould the front headliner be tan like my headliner or T9 like above my door panels. Also not sure if the inside of my posts should be T3 like the exterior or T9 like the interior metal parts.
Thanks,
Carl
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: Got a Bronze Hardtop or Coupe with saddle interior? [Re: 69rrgrabber] #1675738
09/27/14 03:38 AM
09/27/14 03:38 AM
Arizona
Arizona
Bump
Re: Got a Bronze Hardtop or Coupe with saddle interior? [Re: 69rrgrabber] #1675739
09/27/14 12:17 PM
09/27/14 12:17 PM
So. Illinois
bronze69 Offline
bronze69  Offline
So. Illinois
Here's what I got. It's a little hard to read, but the dash, steering column, and the front windshield/ headliner molding are all the same shade of suede finish. The inner door, rear quarter upper panel, and roofrail/ headliner moldings are all the same shade and finish.
I just finished painting a saddle interior '69 myself, with the research I did, everything I found showed the inner posts painted the same color as the inner door. So, that's what I did.
Hope this helps.
68 Gold Met. 383-4spd Roadrunner 69 T5 Hemi 4-spd Roadrunner 70 Limelight 440-6 Auto Superbird
Re: Got a Bronze Hardtop or Coupe with saddle interior? [Re: bronze69] #1675740
09/29/14 02:24 PM
09/29/14 02:24 PM
Arizona
Arizona
Thank you so much for the attachment, that helps a lot! So that front trim piece is the same as the dash, in suede too, that is very interesting. Well on your dash pad and front dash pads, did you end up using a dye? I'd like to know where you found your paints and what you did for the suede finish.
Thanks,
Carl
Re: Got a Bronze Hardtop or Coupe with saddle interior? [Re: 69rrgrabber] #1675741
09/29/14 07:24 PM
09/29/14 07:24 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
I had a 69 T7 bronze Charger 500 with saddle tan interior. I will see what interior pictures I may have.
Troy
Houston Mopar Connection Club
Re: Got a Bronze Hardtop or Coupe with saddle interior? [Re: 69rrgrabber] #1675742
09/30/14 12:31 AM
09/30/14 12:31 AM
So. Illinois
bronze69 Offline
bronze69  Offline
So. Illinois
Thanks,
Carl
I got both paints from Instrument Specialties
As far as the dash pads, I have not gotten that far yet. The car is still in the process of being assembled.
