Engine stand bolt size 440 ci. #1675574
09/22/14 07:25 AM
09/22/14 07:25 AM
6T4 Polara Offline OP
Will be getting a stand and 440 engine need to know what size bolts to hang engine on stand.
Re: Engine stand bolt size 440 ci. [Re: 6T4 Polara] #1675575
09/22/14 08:53 AM
09/22/14 08:53 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
They are 3/8-16 thread size, we can't tell you the length without seeing your engine stand.
What I do and have been doing for 20 years is use all thread and a nut a washer. I have hung many heavy truck engines this way including my hemis.
That way you can be sure it's screwed into the block all the way. Studs are always better. Grade 5 is fine, you don't need grade 8.
