Re: please share your gen 3 Hemi build
[Re: Cevidicus]
#1675092
10/18/14 10:52 AM
10/18/14 10:52 AM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Anybody have a part number for a 6.4 crank and a 6.4 short block?
Short block 68086564AB orRL086564AB Crankshaft 5038339A
[Re: MattW]
#1675093
10/18/14 10:55 AM
10/18/14 10:55 AM
Posts: 3,433 Toronto
mshred
Toronto
The 6.4 crankshaft is forged, correct?
Does anybody know if the 6.4 crank has the same oiling issues as a 5.7 crank does? Wondering if it is a good alternative to aftermarket forged crank for a stroker 5.7 motor.
[Re: mshred]
#1675094
10/18/14 01:42 PM
10/18/14 01:42 PM
MattW
Ontario Canada
AFAIK the oiling is the same. The crank is forged. Matt
[Re: STEFF]
#1675096
10/18/14 03:12 PM
10/18/14 03:12 PM
MattW
Ontario Canada
Just curious why anyone wants to run a stock crank when the aftermarket cranks are a better piece and not that much more expensive...
But I bought mine for half the price that they are now.
[Re: MattW]
#1675097
10/18/14 04:00 PM
10/18/14 04:00 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
I think the idea that the cranks are causing oiling issues is mostly BS.
Stanton Racing (drag pak builder) told me the drag pak cars need 11.5 quarts between the pan and accusump. And there are at least a half dozen guys running stock 6.1 cranks shifting at 8200-8600 rpm and all have been fine for 2+ years.
Also- for those planning builds- the VVT motor cranks require machining if you want to run them in a non-VVT motor.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: Uhcoog1]
#1675098
10/18/14 05:24 PM
10/18/14 05:24 PM
Posts: 361 Canada
onig
Canada
What makes a VVT crank different from a non VVT? What machining steps are required?
69 Dart
[Re: STEFF]
#1675099
10/18/14 05:31 PM
10/18/14 05:31 PM
mshred
Toronto
I agree 100% with you Stef as the Molnar stuff is only like $100 more...But you never know when you might catch a good deal on a 6.4 crank, and I just thought I would ask since I was unsure if the oiling issues was restricted to 5.7s only, or also 6.1's and 6.4's also.
[Re: onig]
#1675100
10/18/14 06:05 PM
10/18/14 06:05 PM
Posts: 3,893 Smyrna, South Carolina
STEFF
Timing gear is positioned further forward on the VVT crank. Would need to machine the crank snout to work in non VVT motor.
[Re: onig]
#1675101
10/18/14 06:14 PM
10/18/14 06:14 PM
MattW
Ontario Canada
Lets see if I can explain this correctly.
The VVT crank needs the snout where the crank timing gear rest against to be machined so the gear sits in the same factory location on an NON VVT block. Simple process. The cam in a VVT block is longer. Steff posted some pics when he built his 6.4. Matt
[Re: onig]
#1675106
10/19/14 10:07 AM
10/19/14 10:07 AM
MattW
Ontario Canada
Does this also apply to 5.7 and 6.1?
No. The only ones affected were the 6.4 and the 5.7 eagle head motors. 09 and up for the 5.7. I think the 6.4 came out in 2011.
[Re: MattW]
#1675107
10/19/14 10:15 AM
10/19/14 10:15 AM
Posts: 361 Canada
onig
Canada
6.1 engines did not come with VVT?
69 Dart
