Page 8 of 16 1 2 6 7 8 9 10 15 16
Re: please share your gen 3 Hemi build [Re: Charger453] #1674950
10/01/14 08:46 PM
10/01/14 08:46 PM
old westchester
mcat4321 Offline
mcat4321  Offline
old westchester
On my build I have a stock 2005 shortblock I have a stock set of 2009 Eagle heads. I use the eagle injectors and. intake. I got .075 head. Gaskets with proper push rods. All these parts I got off ebay and know nothing about.... completely stock stuff. I am using an HHP phase 3 naturally aspirated camshaft I have an aftermarket 85 mm throttle body and I am using a mega squirt from EFI source professionally tuned. I am fairly certain the valve springs and lifters are s*** during Drag Week I ran 12.11@ hi 112 mph in the quarter mile I was getting about 17 mpg all of this in my 3100 pound and my 1968 Barracuda I have a 373 gear and a 27 inch tall drag radial full exhaust the converter stalls at 3100 rpm I think the lifters and valve springs are holding it back for now it revs really weak. I am still playing with timing and shift rpms I'm really not happy with this performance so far
Re: please share your gen 3 Hemi build [Re: mcat4321] #1674951
10/01/14 09:00 PM
10/01/14 09:00 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What lifters and springs are you using? I hope I dont encounter the same problems. I have a set of Manley Nextek springs and a set of lifters out of a 6.1 with about 35K on them.
Mopar to the bone!!!
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674952
10/01/14 09:02 PM
10/01/14 09:02 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Just some comments after reading this thread that may be helpful. Not trying to be a "know it all", just sharing what I have experienced.
We have a 3700# car, NA, 430ci going 10.0 in the heat and should nick 9's shortly.
if you don't mind, what is the gear and converter combo your running?
The rear gear in the 10.0 car is 3.06 with a 28" tire. Converter flashes around 4000. Car 1.40 60's and is trapping at 135.
To use the Apache heads you will need pistons with valve relief, valve covers and pushrods.
As far as running these on a 5.7 it depends on your power goals. When we had the quickest 5.7 in the MSHS series we were running the Apaches with good results.
OST Dyno - Home of the worlds Quickest and Fastest Supercharged Hellcat!
Building and tuning record setting Gen III Hemi’s since 2006!
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1674953
10/01/14 09:08 PM
10/01/14 09:08 PM
old westchester
mcat4321 Offline
mcat4321  Offline
old westchester
stock oem i know nothing about...other than cam and TB these are junkyard parts
Re: please share your gen 3 Hemi build [Re: mshred] #1674954
10/01/14 09:15 PM
10/01/14 09:15 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
However much power stock parts can handle lol...I have no interest in building a G3 hemi to only go and spend coin on Thitek heads. To me, the appeal of the hemi is how well the stock heads flow, both as cast and ported. Combine that with a good bottom end, and I can't see why 8-900hp isn't attainable.
I do want to stay 5.7 for blocks because of cost and availability....If the 6.4 head is really no good on that bore size, I will save my cash and put some work in to the stock 5.7 heads
Don't wast your time or money on the stock 5.7 heads. The Apaches are relatively inexpensive and will work on the 5.7 with the proper pistons.
You are going to have a really difficult time getting 8-900 wheel HP out of a 5.7 w/5.7 heads (even with serious head work). I really don't think you will be able to hit that number.
If you can't afford the Apaches try to find a set of 6.1 heads. We made 750-790whp on a completely stock 6.1 at 18psi on C85 - but that is really on the bleeding edge and wouldn't have lasted long.
As far as heads holding - the stock 6.1 mentioned above didn't come apart until 25psi and the factory heads w/factory head bolts and gaskets showed no signs of lifting. The failure appeared to be the stock rod bolts. Again, this is bleeding edge and only an experiment to see what a stock 6.1 could handle. That engine at 14psi powered the Jeep to a 10.7@130 in Bowling Green - making it the quickest completely stock block Jeep on record.
Buy a set of 6.1 heads used ($900?) and freshen them up. Build a forged bottom or at least a 6.1 crank ($150) and some good rods and pistons. Have PWR spec you a turbo cam and put an 80mm on it. Then you will hit your whp number.
Re: please share your gen 3 Hemi build [Re: 1badx] #1674955
10/01/14 09:31 PM
10/01/14 09:31 PM
Toronto
mshred Offline
mshred  Offline
Toronto
As far as heads holding - the stock 6.1 mentioned above didn't come apart until 25psi and the factory heads w/factory head bolts and gaskets showed no signs of lifting. The failure appeared to be the stock rod bolts. Again, this is bleeding edge and only an experiment to see what a stock 6.1 could handle. That engine at 14psi powered the Jeep to a [Email]10.7@130[/Email] in Bowling Green - making it the quickest completely stock block Jeep on record.
Will the Apache heads work with just a valvespring, retainer, lock swap, or do they need new valves also to run in higher hp applications?
What about the 5.7 eagle heads? I figure with enough boost per ci, 800hp should be a number not too difficult to attain.
Are the pistons necessary for the Apaches on a 5.7 expensive custom pieces, or are they becoming an "off the shelf" deal as of late?
With the deal on the 6.4 heads right now, I want to pull the trigger...I just want to know that they will be worth it knowing that almost indefinitely they will be going on a 5.7
Re: please share your gen 3 Hemi build [Re: 1badx] #1674956
10/01/14 10:27 PM
10/01/14 10:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Was it the 5.7 in the trucks that had the mds or is
it the cars... sure is pretty hard to find a 6.1
Re: please share your gen 3 Hemi build [Re: 1badx] #1674957
10/01/14 10:49 PM
10/01/14 10:49 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Well, that sucks, my car is a damn turd
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674958
10/01/14 10:50 PM
10/01/14 10:50 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
What first gear ratio with those 3.06 gears?
68 Barracuda Formula S 340
Re: please share your gen 3 Hemi build [Re: 1badx] #1674959
10/01/14 11:25 PM
10/01/14 11:25 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I could've swore Andy said the 5.7 needed a bore notch? I wanted to run a set of Apaches but I took a stock 6.1 valve and set it in my Manley piston valve notch, it is barely adequate for even the 2.08 valve.
Re: please share your gen 3 Hemi build [Re: Bad340fish] #1674960
10/01/14 11:27 PM
10/01/14 11:27 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
NAG1's have a 3.59 1st according to google.
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674961
10/02/14 12:08 AM
10/02/14 12:08 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Trucks got MDS in '06. 5.7 MDS started in '05 in cars. No MDS in 6.1 AFAIK.
Kevin
Re: please share your gen 3 Hemi build [Re: Twostick] #1674962
10/02/14 12:37 AM
10/02/14 12:37 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Kevin
Thanks... it looks like I'm gonna have to go with
this truck 5.7 I've been looking at... cant even find
any 6.1s in the area... bummer.... anyone know of
any complete 6.1s within a reasonable distance from
Detroit... been mainly looking at Craigslist
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674963
10/02/14 12:58 AM
10/02/14 12:58 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Here's 4 but probably overkill for your intended purpose.
Nigel is a member here.
http://nationalmoparts.com/c-body-parts?...category_id=447
Kevin
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674964
10/02/14 01:25 AM
10/02/14 01:25 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Look on the LXForums, they pop up on there quite often, was a long block 6.1 with low miles for $3500 recently
Re: please share your gen 3 Hemi build [Re: Twostick] #1674965
10/02/14 01:27 AM
10/02/14 01:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Kevin
Yeah thats way more than I plan on paying... hell
I can get a used 6.1 supercharged for less than that
but who knows what kind of shape its in... but thanks
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674966
10/02/14 09:00 AM
10/02/14 09:00 AM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
If I read correctly you said you've only been to the track once and your car went 10.0? What MPH? What was your 60'?
Depending on the compression your getting with those heads and pistons I would think at your weight you should be in the high 9's but if your compression is low enough then maybe not.
I'm not familiar enough with your intake/induction as far as track testing to make a call on that.
Re: please share your gen 3 Hemi build [Re: 1badx] #1674967
10/02/14 09:16 AM
10/02/14 09:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm still trying to get a feeling on these gen 3s...
what kind of compression are most running.. both N/A
and boosted... from what Rick said on his, I have a
feeling a person can go pretty damn high on pump fuel
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674968
10/02/14 09:30 AM
10/02/14 09:30 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
So, if I find a 6.1 block I can run 6.4 heads with no issues?
Re: please share your gen 3 Hemi build [Re: justinp61] #1674969
10/02/14 10:23 AM
10/02/14 10:23 AM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
This thread is awesome! I just picked up a set of Arrington cnc ported eagle heads with the valve size upgraded and new Manley valves, and a 2012 low mike 5.7 block off a member here to get the ball rolling. Planing on quality forged bottom end to handle boost from a Large F1 or maybe even a F2 procharger. Plan on blowing it in through a modified 6.1 intake so I can keep it under the hood. Wanting an 8.?? at 150 plus time slip to frame!! Will be in a purpose built 71 demon.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
