Page 10 of 16 1 2 8 9 10 11 12 15 16
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674990
10/02/14 06:57 PM
10/02/14 06:57 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Just flowed my 6.4 head
.2 168
.3. 242
.4. 287
.5. 318
.6. 330
5.7 eagle head on my bench
.2. 144
.3. 220
.4. 275
.5. 300
.6. 300
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674991
10/02/14 07:17 PM
10/02/14 07:17 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The .300 and .400 flows are what get me almost more than the peaks.
Mopar to the bone!!!
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1674992
10/02/14 08:07 PM
10/02/14 08:07 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
With all this good info, I can't decide if I want to build a NA motor or hang a 76mm-80mm turbo on one!!!!!!!!!!
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674993
10/02/14 08:12 PM
10/02/14 08:12 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
What was the part number on the box those 6.4 heads came in?
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: please share your gen 3 Hemi build [Re: Dave_S] #1674994
10/02/14 08:28 PM
10/02/14 08:28 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
68086555AA
68086556AA
I have 2 small turbos, and with the bigger chamber on the 6.4 heads, I'm thinking its probably time to just do it
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674995
10/02/14 08:54 PM
10/02/14 08:54 PM
Dave_S Offline
Dave_S  Offline
those are $775 each plus core up here! And I work at a dealer!
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: please share your gen 3 Hemi build [Re: Dave_S] #1674996
10/02/14 09:04 PM
10/02/14 09:04 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
www.rtpartsco.com
Put in 2013 dodge charger, goto engine, goto cylinder heads
There they are
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674997
10/02/14 09:06 PM
10/02/14 09:06 PM
Arizona
Chris'sBarracuda Offline
Arizona
One of the most informative threads in a long time.. Keep it up..
Chris..
Re: please share your gen 3 Hemi build [Re: 1badx] #1674998
10/02/14 10:25 PM
10/02/14 10:25 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
This pic is of a stock replacement 6.4 piston from Manley
http://www.southeastrt.net/images/597400-main.jpg
This is a pic of my Manley's which must be an older design.
Nice! I love the thicker ring land!
Here's mine installed in my 5.7 block:
Are these 6.4 pistons in a 5.7 block?
Re: please share your gen 3 Hemi build [Re: WO23Coronet] #1674999
10/02/14 10:52 PM
10/02/14 10:52 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
A 2.16 ls valve in my valve relief
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1675000
10/02/14 11:06 PM
10/02/14 11:06 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Just curious how much boost could you put to one of these reliably with an after market rotating assembly...
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1675001
10/02/14 11:49 PM
10/02/14 11:49 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
yeah dont remind me Ray. My pistons were probably made before Apaches even existed. It's all good, its going in a Road Course car. But I would love to lay down a 10.99 or quicker after bolting the 28x12.5x15 ET Streets I have in the shed.p
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1675002
10/02/14 11:58 PM
10/02/14 11:58 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
I think you can rent a cutter from isky if needed
Re: please share your gen 3 Hemi build [Re: Dragula] #1675003
10/02/14 11:59 PM
10/02/14 11:59 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Completely stock 6.1 held 18psi for quite a while but keep in mind I tune quite a few of these, "snuck up" on this tune, checked plugs regularly and do have a dyno to experiment with. I really believe the tune has alot to do with making these engines live and perform.
As far as how much a forged rotating assembly will take - I'm not sure we know that yet. There's been quite a few that I have heard about that gave out at 14+psi but I believe this was due to other issues (i.e. mechanical, bad fuel, overheating, improper tuning). I'm at 18-20 psi with the Jeep right now and have made a full pass at 23psi but was pushing through the converter. So until Joe at ProTorque get's me squared away with a better setup I am stuck here. There are a few others out there that I have tuned in the 18+psi range that are running regularly but really having issues putting the power to the ground. We also have a twin turbo, 6 speed Challenger in the shop right now that makes 1000+whp at 18-19psi (5.7 based 370ci), idles at 650 and is quite as a church mouse until the turbo's come to life - then it's a handful. The trans I believe (and afraid about) is the limiting factor here as well.
To answer the question about the pistons in my 5.7 block - those are aftermarket pistons designed to work with any available head and I am currently running Thitek's w/inconnel exhaust valves.
OST Dyno - Home of the worlds Quickest and Fastest Supercharged Hellcat!
Building and tuning record setting Gen III Hemi’s since 2006!
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1675004
10/03/14 12:50 AM
10/03/14 12:50 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
www.rtpartsco.com
There they are
That is a cool site. Do all the heads come with valves, springs, etc or are they bare?
RMRW 2018
RMRW 2020
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1675005
10/03/14 01:08 AM
10/03/14 01:08 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
rotator is balanced and picking up a set of PWR 6.1 heads today. The Apache ship has left the station on this engine. That 20-30rwhp I could've had will just have to wait for another day. Mine are supposed to flow in the 360-370 range at .600.
Re: please share your gen 3 Hemi build [Re: 1badx] #1675006
10/03/14 01:10 AM
10/03/14 01:10 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
yep is was funny is that video watching him try to get down the track lol.
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1675007
10/03/14 10:41 AM
10/03/14 10:41 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
the 6.1 head does flow very well. I would be happy with what you have
Re: please share your gen 3 Hemi build [Re: BBR] #1675008
10/03/14 10:45 AM
10/03/14 10:45 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
www.rtpartsco.com
There they are
yes,complete! they even have spark plugs! that is where I bought my Eagle heads for $222 each
and now the 6.4 heads for $620 each
Re: please share your gen 3 Hemi build [Re: 1badx] #1675009
10/03/14 11:47 AM
10/03/14 11:47 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Mike at that boost level what valvesprings and lifter setup are you using?
