Page 7 of 16 1 2 5 6 7 8 9 15 16
Re: please share your gen 3 Hemi build [Re: headhunter] #1674930
09/30/14 08:07 PM
09/30/14 08:07 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
the special carb deal is the carb is being built by one of the best carberator guys in the country and tuned by him on the motor on a dyno that's what is meant by the special carb
Be sure and post an let us know how the tuning works out - it would be great if someone got onto an effective way of running a single carb.
Re: please share your gen 3 Hemi build [Re: Moparmal] #1674931
09/30/14 08:27 PM
09/30/14 08:27 PM
ky
headhunter Offline
headhunter  Offline
ky
im hopeing he can do something on mine as well even tho its a csu carb
Re: please share your gen 3 Hemi build [Re: headhunter] #1674932
09/30/14 08:29 PM
09/30/14 08:29 PM
ky
headhunter Offline
headhunter  Offline
ky
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1674933
10/01/14 11:53 AM
10/01/14 11:53 AM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Just some comments after reading this thread that may be helpful. Not trying to be a "know it all", just sharing what I have experienced.
- The Apache heads will fit on a 5.7 block
- Another alternative for good heads is Thitek
- The 5.7 block is a cheaper and more readily available alternative.
- If using a truck 5.7 block you will need to account for the different dipstick location and if using a pan with a dipstick tube you will need to plug the dipstick tube hole in the truck block.
- If using a 5.7 truck block and a 6.1 timing cover and AC you will need to drill and tap 2 holes for the AC bolts in the block.
- To delete MDS just replace the lifters. You can leave the MDS components in place - no need for plugs.
- These engines do not like a lot of timing so be careful.
- Stick with fuel injection and a 6.1 intake for most applications.
- NA or forced induction they can make a decent and reliable HP#
We have a 3700# car, NA, 430ci going 10.0 in the heat and should nick 9's shortly.
We also have a 5300# Jeep, turbo, 370ci going high 9's and daily driven.
These engines are impressive and I can't wait to see when someone really starts pushing them!
OST Dyno - Home of the worlds Quickest and Fastest Supercharged Hellcat!
Building and tuning record setting Gen III Hemi’s since 2006!
Re: please share your gen 3 Hemi build [Re: 340RICK] #1674934
10/01/14 12:19 PM
10/01/14 12:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok guys David Barton did my lifters. I was at his shop and he took them apart while I was there. There is really not much inside them. He told me sometimes he will put the spring back in the lifter sometimes no. I believe mine have nothing in them No spacers shims etc. I have a few sets of lifters I will try and take some apart and get some pics to share.
Not sure on my compression but cranking compression is 240 PSI
Rick.... you have 240 cranking pressure and you run
PUMP GAS... I would never have thought that... I know
the timing is a lot less with the gen 3 but damn thats
a lot of cranking pressure.... sure opens my mind up
on this engine
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674935
10/01/14 04:23 PM
10/01/14 04:23 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
they're here
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674936
10/01/14 04:25 PM
10/01/14 04:25 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Re: please share your gen 3 Hemi build [Re: 1badx] #1674937
10/01/14 04:53 PM
10/01/14 04:53 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
if you don't mind, what is the gear and converter combo your running?
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674938
10/01/14 04:54 PM
10/01/14 04:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ray.. which head is that... and if you dont mind..
what kind of price and is that ported or stock form
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674939
10/01/14 05:00 PM
10/01/14 05:00 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
stock 6.4 head. was just on sale for $470+$150 core charge each
they are still on sale. I was told they are going thru a part number change that is why the great price
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674940
10/01/14 05:14 PM
10/01/14 05:14 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Awesome Ray! I bit the bullet and am going with Mean Street 6.1's for now. My cam and piston combo made Apaches too much of a roll of the dice. I think my 8 3/4 will thank me later anyway....
Mopar to the bone!!!
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674941
10/01/14 05:14 PM
10/01/14 05:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is that assembled just like you show there..
any idea what they flow as is
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674942
10/01/14 05:15 PM
10/01/14 05:15 PM
ky
headhunter Offline
headhunter  Offline
ky
Are they better than a 5.7 or 6.1 head?
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674943
10/01/14 05:15 PM
10/01/14 05:15 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Ive seen 340cfm at .600 and .700 reported on them OOTB.
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1674944
10/01/14 05:20 PM
10/01/14 05:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats pretty nice for OOTB heads... hows the exhaust
side of these...I'm about 90% sure I'll be going turbo
Re: please share your gen 3 Hemi build [Re: 1badx] #1674945
10/01/14 05:23 PM
10/01/14 05:23 PM
Toronto
mshred Offline
mshred  Offline
Toronto
What kind of changes are necessary for the 6.4 heads to work on the 5.7 bore? Just a notch of the bore? Special piston valve reliefs? Would like to jump on a set of 6.4 heads if they can be used on a 5.7 block efficiently...if they are a waste on a bore that small, or not worth the work, then I am just going to pass.
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674946
10/01/14 05:27 PM
10/01/14 05:27 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I wouldnt use these on a 5.7 block personally. How much power are you shooting for? The best head for all out turbo use IMO would be the Thitek's because of the thicker decks and better quality of material across the board. In a turbo application I think you would run out of sealing with any stock head before the Apaches would show a distinct power advantage.
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1674947
10/01/14 07:22 PM
10/01/14 07:22 PM
Toronto
mshred Offline
mshred  Offline
Toronto
However much power stock parts can handle lol...I have no interest in building a G3 hemi to only go and spend coin on Thitek heads. To me, the appeal of the hemi is how well the stock heads flow, both as cast and ported. Combine that with a good bottom end, and I can't see why 8-900hp isn't attainable.
I do want to stay 5.7 for blocks because of cost and availability....If the 6.4 head is really no good on that bore size, I will save my cash and put some work in to the stock 5.7 heads
Re: please share your gen 3 Hemi build [Re: mshred] #1674948
10/01/14 07:52 PM
10/01/14 07:52 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I was replying to Mr.P. I'm not gonna tell someone to not try something without having done it myself. Will the Apache bolt on to a 5.7? Hell yes. Will you need a bore notch? I know I have read that you do. So what, for the price of these heads it is probably worth it compared to no heads at all im sure. They do need an intake that can be opened to their huge ports though. People have said the smaller heads have better velocity but at 8000rpm I bet it evens out.
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1674949
10/01/14 07:57 PM
10/01/14 07:57 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Sorry, I assumed you were responding to me since there was no quote and it was right after my post....you make a good point about the Apache's though...
