Page 5 of 16 1 2 3 4 5 6 7 15 16
Re: please share your gen 3 Hemi build [Re: 340RICK] #1674890
09/25/14 12:03 AM
09/25/14 12:03 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
6.1 stroker 426ci
Manley stroker kit
Bullet solid roller .659/.678 262/276
6.1 heads CNC by Modern touched up and valve Job by David Barton 2.10x1.1.60 valve
Harland Sharp rockers 3/8 push rods
Drag Pak manifold untouched
Fast 4150 throttle body
Fast XFI/2.0
Made [Email]776HP@7400rpm[/Email] and [Email]610ftlbs@6100rpm[/Email]
best of 9.61 at 139mph
Rick, how are you liking the XFI? Also, what are your static and dynamic compression numbers?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: please share your gen 3 Hemi build [Re: mshred] #1674891
09/25/14 01:19 AM
09/25/14 01:19 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
6.1 stroker 426ci
Manley stroker kit
Fast XFI/2.0
What lifters? and what rocker arms? Are they the ones that have a 2k price tag? Last I remember hearing mentioned was that no one is making solid roller lifters yet for the new hemis, and that aftermarket rockers were VERY expensive.
Car runs HARD though Rick! Everytime I see your sig and read about your combo, it makes me want a G3 even more!
What ive heard guys do with the solid rollers is converter the stock lifters to solid via some spacers. The stockers are that good and I have a couple sets and the things are beefcake 100%. I have a set of 6.1 heads I would be glad to part with that would be great for your 5.7 to Shred. Im gonna use them if I cant find someone who can use them, I have to sell them though to afford some Apaches.Edit: I'm gonna keep the 6.1 heads.
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1674892
09/25/14 06:34 PM
09/25/14 06:34 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
I am using stock non MDS lifters that are gutted and had a solid roller grind cam made for it.
Also I do have the Harland Sharps that are not cheap
Alex The FAST XFI is great now that the motor is happy. I had so many issues with the HYD roller cam and non ADJ rockers valve springs push rods etc... that I had motor issues not EFI tunning issues like I first thought.
Re: please share your gen 3 Hemi build [Re: 340RICK] #1674893
09/25/14 07:06 PM
09/25/14 07:06 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Good to hear, what magic is there in your lifters?
Also, what is the static and dynamic compression?
Re: please share your gen 3 Hemi build [Re: 340RICK] #1674894
09/25/14 08:56 PM
09/25/14 08:56 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Spring pressures collapsing the lifters making it run poorly? Mine seems to do that for a few minutes
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1674895
09/26/14 12:31 AM
09/26/14 12:31 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I just saw this....
Re: please share your gen 3 Hemi build [Re: 340RICK] #1674896
09/26/14 12:33 AM
09/26/14 12:33 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Gutted and fitted with a custom spacer? I guess going solid roller required the use of those Harland Sharp rockers also?
What weight is your car running those times at?...very impressive Rick!
Re: please share your gen 3 Hemi build [Re: mshred] #1674897
09/26/14 01:13 AM
09/26/14 01:13 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
This is my favorite thread evaaarrrrr.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: please share your gen 3 Hemi build [Re: BBR] #1674898
09/26/14 08:54 AM
09/26/14 08:54 AM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Soaking all this in like a sponge as I am in the planning and parts gathering stage of my Gen3 build. Keep the info coming! Rick did Barton modify your lifters?
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: please share your gen 3 Hemi build [Re: Quickrunner] #1674899
09/26/14 10:45 AM
09/26/14 10:45 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Hurry while the blocks are still available!
Mopar to the bone!!!
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1674900
09/26/14 11:02 AM
09/26/14 11:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
On a 5.7 or a 6.1.. is there certain year blocks that
are better than others... as in I'm looking at a 2005
5.7 thats suppose to be a running engine
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674901
09/26/14 12:27 PM
09/26/14 12:27 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
No, they're all the same. I'd run a 5.7 block in a really high hp application over a 6.1. Just do a partial fill and run a really good oil cooler.
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674902
09/26/14 12:30 PM
09/26/14 12:30 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Any year 6.1 is a win. I have read the early 03-04 5.7 block were thicker walled. An 05 5.7 is as good as any other 5.7 but it also has the benefit of no plug wires and no mds coming from a truck.
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1674903
09/26/14 12:39 PM
09/26/14 12:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This engine is coming out of a truck so MAYBE I should
continue to look... what does it take to kill
the MDS... to my understanding the lifters have a
slot in them for the solenoid to push something in
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674904
09/26/14 12:42 PM
09/26/14 12:42 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
You just need 4 MDS delete plugs from a 6.1 or HD 5.7. If you leave the solenoid in the block but unplugged, it will do weird things. Use the plugs and be done.
Re: please share your gen 3 Hemi build [Re: MR_P_BODY] #1674905
09/26/14 12:50 PM
09/26/14 12:50 PM
Renton Washington
Triple Threat Offline
Renton Washington
05 5.7 from a truck shouldn't have MDS, so the one you found is what you want.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: please share your gen 3 Hemi build [Re: Triple Threat] #1674906
09/26/14 04:56 PM
09/26/14 04:56 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
^^^^ that's what I thought I said lol....
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1674907
09/26/14 06:16 PM
09/26/14 06:16 PM
Bellevue, NE
Charger453 Offline OP
Bellevue, NE
The look of the later engines with no plug wires is definitely cleaner. What's needed to change to them? Just the later coils and the connectors?
Re: please share your gen 3 Hemi build [Re: Charger453] #1674908
09/26/14 06:24 PM
09/26/14 06:24 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
05-08 valve covers too.
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1674909
09/26/14 06:35 PM
09/26/14 06:35 PM
Bellevue, NE
Bellevue, NE
Sounds easy enough. Thanks.
