Page 4 of 4 1 2 3 4
Re: I over torqed my tie rod end...what should I do? [Re: 62maxwgn] #1674690
09/23/14 07:12 PM
09/23/14 07:12 PM
BDW Offline
BDW  Offline
Any chance the taper is upside down like in the recall?
Sorry, couldn't help myself
Don't waste your time or money, add a washer and be done with it.
Re: I over torqed my tie rod end...what should I do? [Re: BDW] #1674691
09/25/14 01:53 PM
09/25/14 01:53 PM
Delaware
GeorgeH Offline
GeorgeH  Offline
Delaware
That's the last straw, imma throw my tie rod shims back in the tackle box I call a toolbox and I'm headed home!
Re: I over torqed my tie rod end...what should I do? [Re: plazomat] #1674692
10/05/14 04:20 AM
10/05/14 04:20 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
-I took the nuts off the rod tonight - threads looked ok - I have a ball joint seperator coming in Wednesday to pull the joint and not damage it so I can post pictures and hopefully prove someone right...replace the rod anyway since I am there again.
Plaz-o-mat
Pictures and report please.
Re: I over torqed my tie rod end...what should I do? [Re: plazomat] #1674693
12/01/14 02:37 AM
12/01/14 02:37 AM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
OK Gents, just a quick update, did this a while back.
When inspecting the tie rod end I removed, it looked fine. Also on this moog part anyway there was no way I could have pulled the ball from is socket. At the end of the taper near the bar the shaft has a flat spot machined in it where the shaft increases in diameter..this flat comes up against the bottom of the hole and the worst I could do was stretch the shaft...not likely.
I installed the new tie rod end torqued to 40 and dam thing lined up the exact same way ? I put a washer under the nut to raise it up and called it a day...it will stay like this.
I did forget to mention earlier I installed the bigger C-Body rod ends on my 69 B-body suspension if that would have changed anything I do not know...
Thank you all for your help.
PLAZ
Re: I over torqed my tie rod end...what should I do? [Re: plazomat] #1674694
12/01/14 02:54 AM
12/01/14 02:54 AM
Plaz before you go we need pics!
Re: I over torqed my tie rod end...what should I do? [Re: plazomat] #1674695
12/01/14 03:34 AM
12/01/14 03:34 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
You know, I did the exact same thing, and I asked ole Rick from Mopar Action what to do, and guess what he said? Don't worry about it, and that is exactly why the FACTORY nuts only had three tangs on them.
Re: I over torqed my tie rod end...what should I do? [Re: RapidRobert] #1674696
12/01/14 10:23 PM
12/01/14 10:23 PM
plazomat Offline OP
plazomat  Offline OP
Robert, the car has been put away for the year...Canadian weather....
I should remember in the spring and take a pic then of the nut/washer/tie rod end...
Again thanks for all the help.
PLAZ
Re: I over torqed my tie rod end...what should I do? [Re: GODSCOUNTRY340] #1674697
12/02/14 03:08 PM
12/02/14 03:08 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I didn't say the taper was too small, I said maybe too low on the shaft. If a manufacturer is unable to supply the correct castle nut can that same manufacturer be relied on to machine the taper correctly on a shaft? All it would take is 1/4" off.
Im still waiting to hear where in the recall notice it says over tightening the nut causes ball/socket to come apart. I think theres some spin going on here.
Keep old mopars alive.
Page 4 of 4 1 2 3 4
