Re: I over torqed my tie rod end...what should I do?
[Re: therocks]
#1674650
09/21/14 09:47 PM
09/21/14 09:47 PM
Posts: 4,956 WI
Dcuda69
WI
Jim I think some of this stuff is way over thought.I can tell these guys never worked in a garage at flat rate.Zip them in with your impact.Just dont go wild doing it.That was on daily drivers that saw more miles in a month than most of these will see in 2 years. Rocky
I've put literally 1000's of these together on daily driver cars of all types. I can't remember torquing many with a wrench. Zip them on,pop the cotter in and go. If the castle nut don't line up I'd be looking at the nut more than anything.....doubt you could stretch a hardened stud at 80 ft lbs.
[Re: Dcuda69]
#1674651
09/22/14 12:18 AM
09/22/14 12:18 AM
Posts: 2,529 God's Country Maryland
GODSCOUNTRY340
There's got to be a reason the castle nut if too far below the cotter pin hole. Either he stretched the shank or the ball is pulling from the socket. Don't tell me the ball won't come out of the socket, that's exactly what happens when they fail. Plus, these are most likely parts made in China, do you really want to trust your families lives or other motorist lives on a sub-standard Chinese part? My son worked at a bolt supply store and would get cases of grade 8 bolts in and find many with the heads popped off the bolts. They had to sort through them to remove the bad bolts before putting them out for sale. They were told to never tell the public about this process.
[Re: therocks]
#1674652
09/22/14 12:29 AM
09/22/14 12:29 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Seriously ??
[Re: GODSCOUNTRY340]
#1674653
09/22/14 12:31 AM
09/22/14 12:31 AM
JohnRR
U.S.S.A.
You're wasting your breath , only flat rate monkeys have a clue how anything can be put together .
I've had to fix more stuff screwed up by someone trying to make 16hrs of pay in an 8 hour day ...
[Re: JohnRR]
#1674654
09/22/14 12:34 AM
09/22/14 12:34 AM
Posts: 15,469 Omaha Ne
TJP
Omaha Ne
Seriously ??
A flat rate garage sending out something that might cause a problem??? Tell me it isn't so
MY
#1674656
09/22/14 04:11 AM
09/22/14 04:11 AM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
You can not pull the tapered stud through the tapered hole. It will snap off long before that happens and 70-80 ft/lbs is not going to do that. As for pulling the ball from the socket, that doesnt even make sense as an explanation of what is or isnt happening. Do you think the ball itself is being pulled through the much smaller tapered hole? Its the incorrect castle nut for this application. Thats the reason the cotter pin hole is above the castellations. I have seen it before and the new part (sometimes) came with a washer and (sometimes) an explanation.
[Re: nomore65BelvJim]
#1674658
09/22/14 12:02 PM
09/22/14 12:02 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Jim and Gus you wont change their minds.Especially John.He is the expert in every field and has done tens of thousands.We had quality surveys on everything we did at the shop.We still carried a 98% approval rating. As for the balls coming out of the sockets yeah they do.Its called wear and being dry also.In 50 years Ive never seen anyone pull a ball out by tighting it.Like I said you guys over think the simple things.Rocky
Chrysler Firepower
[Re: therocks]
#1674659
09/22/14 12:28 PM
09/22/14 12:28 PM
JohnRR
U.S.S.A.
I never said the ball was coming out of the socket, that was something someone else said.
[Re: GeorgeH]
#1674661
09/22/14 01:25 PM
09/22/14 01:25 PM
TJP
Omaha Ne
Your right and these guys saying to slam it together and get it out the door just bring the whole industry down. No clue or care about liability.
It might even have been the right box with wrong part in it with the wrong taper as the Op is only talking about one of the ones he purchased. It needs investigated.
#1674662
09/22/14 01:55 PM
09/22/14 01:55 PM
Posts: 32,970 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
You can't? Then why was my '08 Cummins Ram just recalled for tie-rod end failures? It seems the housings are cracking allowing the ball to come out of the joint. Dakotas had this same problem a few years ago. When the housing cracks there's not much to keep the ball in the joint, It's coming out! Wear alone isn't the only thing that lets the joint come apart, housing failures will let it happen, that's the reason they're recalled.
Not even the same thing. You can't pull the ball out of the socket by tightening the nut. Mainly because you aren't putting any kind of pressure on the socket at all. The tapered shaft will only go so far into the drag link. Yes the socket can break from wear but not by over tightening the nut during installation which is what we are discussing here. Stick to the original subject.
[Re: stumpy]
#1674663
09/22/14 02:00 PM
09/22/14 02:00 PM
Posts: 13,605 md
mopars4ever
md
To answer the question. Do you want to take a chance on it or not? It`s up to you. For me I wouldn`t. Some people like the odds but I don`t. Of course I`m the kind of person that gets new tires before they are completely bald and blow out.
[Re: stumpy]
#1674666
09/22/14 02:59 PM
09/22/14 02:59 PM
therocks
Niles , Ohio
Stumpy it dosent say that.But you will never get the armchair experts to see it.A defect in a part isnt the same as tightening it.Hell to pull a ball out of the socket you would have to destroy the arm and all.Then the top of the stud would snap off first.Its that plain and simple.John I didt say you said that. Rocky
Chrysler Firepower
[Re: therocks]
#1674667
09/22/14 04:48 PM
09/22/14 04:48 PM
GODSCOUNTRY340
How do you know the shaft was made with the correct diameter or even the correct taper? If that shaft is too small it could definitely pull on the ball before it makes contact with the arm. Castle nuts are designed to have the cotter pin go through the towers, not to let it loosen a couple of turns before it contacts the towers. All I'm saying there's something not right there. Here's a suggestion, why don't one of you guys buy the tie-rod off the OP and install it on your car? We'll see how many of you are willing to do that.
[Re: dogdays]
#1674669
09/22/14 08:10 PM
09/22/14 08:10 PM
GODSCOUNTRY340
You're all correct, tie-rod ends can't come apart. I guess Chrysler is wrong too. Chrysler just ordered a recall so they can install free parts on customer's cars. They like losing money.
