Re: indy x heads on 318-390 build
[Re: roadrunnerreds]
#1674625
09/21/14 06:30 PM
09/21/14 06:30 PM
Posts: 5,895 Florida
Locomotion
Just like the 1.88" vs 2.02" in the same OEM head, I don't believe it would be a lot of difference, everything else being equal. But the more radical you go, the bigger the difference will be.
I've run low 11.20's @ around 117 with those LAX heads with no porting, 360, 10.5 compression, .474" cam and footbraking a 904 @ 3,540+ lbs! Both as cast, but blueprinted and a good valve job, I figure they are at least 2 tenths faster than comparable OEM 1.88" heads. Ports are bigger and flow better, plus the slight compression bump. In my case it was about 3 cc difference in the chambers.
I've never had it on a dyno, but I'm leary of the "calculators". They've come up with some very optimistic #'s and vary quite a bit, depending on what formula you use.
[Re: Locomotion]
#1674626
09/21/14 07:08 PM
09/21/14 07:08 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
My 72 Challenger had a very similar build to yours Myron although a 340, same heads and compression, 11.2's @ 117 all day long
Rickster
[Re: rickstershemi]
#1674627
09/21/14 07:19 PM
09/21/14 07:19 PM
Locomotion
Rickster
