1970 E body primer color Hamtramck build #1674588
09/20/14 08:06 PM
09/20/14 08:06 PM
NE Ohio
Govierjr. Offline OP
NE Ohio
Looking for info on undercarriage primer color of early build E body cars. Charcoal grey? Red? Car in question is 9/69 challenger with what looks like both colors. Thanks in advance for responses
Re: 1970 E body primer color Hamtramck build [Re: Govierjr.] #1674589
09/20/14 08:37 PM
09/20/14 08:37 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Resto Rick has what you need.It's a charcoal black.
Re: 1970 E body primer color Hamtramck build [Re: 5carguy] #1674590
09/21/14 11:17 AM
09/21/14 11:17 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
Resto Rick has what you need.It's a charcoal black. [/quote
Huh! What Rick sells is dip GRAY primer
You will sell red primer behind the dash a lot on Mopars
Re: 1970 E body primer color Hamtramck build [Re: hemi70se] #1674591
09/21/14 06:44 PM
09/21/14 06:44 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
My mistake.I ment Frank Badelson.
And charcoal black is for LA built cars.
Re: 1970 E body primer color Hamtramck build [Re: 5carguy] #1674592
09/21/14 08:47 PM
09/21/14 08:47 PM
western australia
1cuda Offline
1cuda  Offline
western australia
when i stripped my challenger vert it had a dark grey primer under the body color but under that in a lot of areas was red oxide primer-more than likely for extra protection. areas such as the fuel filler on the rear quarter-the cowl area-the rear panel where the lead join behind the rear window etc.
all the best
frank.
Re: 1970 E body primer color Hamtramck build [Re: 1cuda] #1674593
09/21/14 09:25 PM
09/21/14 09:25 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
all the best
frank.
The red seems to be on the upper part of the body. I've seen it on paint that worn. Some people mistake it for rust or spot repair.
Re: 1970 E body primer color Hamtramck build [Re: autoxcuda] #1674594
09/23/14 02:12 PM
09/23/14 02:12 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Polyurethane Dip Gray Primer
Dip Gray underbody on your car is correct.
The topside was first primed with a red oxide primer, followed by a light gray primer. Last was the topcoat color obviously. Some of the red oxide, light gray primer & topcoat color would overspray under the body; how much varied greatly... some cars show very little if any of the red or light gray primers and I've seen less common examples where it looked like the painter was using a garden hose applying the red oxide.
If you're lucky enough to have pics of, or the original example to go by, study it carefully for the best reference you can get!
Re: 1970 E body primer color Hamtramck build [Re: RestoRick] #1674595
10/28/14 06:51 AM
10/28/14 06:51 AM
www.mmcdetroit.com
MMC Detroit Offline
MMC Detroit  Offline
www.mmcdetroit.com
See example below
MMC/ ICCA Detroit. The Motor City or where ever there is Mopars
Re: 1970 E body primer color Hamtramck build [Re: Govierjr.] #1674596
10/28/14 10:33 AM
10/28/14 10:33 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Two examples of the dip coat color on 1970 Hamtramck cars;
