Small block rope rear main seal #1674578
09/20/14 06:34 PM
09/20/14 06:34 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
Is there any companies that still make a rope rear main seal for a small block? I can't find anything. This is for a bone stock '68 273.
1968 Valiant Signet 4dr. 273 4spd
1969 Road Runner 383 4spd
1969 Barracuda 318 auto
1970 Dart Swinger 340 4spd
1975 Cordoba 400-4bbl
1988 Caravelle 318 Auto
1999 Dakota R/T
2000 Viper GTS
2001 Ram 2500 Diesel 6spd
2018 Dodge Challenger GT (Winter beater!)
Re: Small block rope rear main seal [Re: D149] #1674579
09/20/14 07:43 PM
09/20/14 07:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
http://www.summitracing.com/parts/fel-bs11748/overview/make/dodge
Re: Small block rope rear main seal [Re: autoxcuda] #1674580
09/20/14 10:05 PM
09/20/14 10:05 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
That is listed for a big block only.
Will it also work with the small block. I understand that the ends are just cut to length, but is the diameter of the seal the same between big and small blocks?
1999 Dakota R/T
2000 Viper GTS
Re: Small block rope rear main seal [Re: D149] #1674581
09/21/14 02:06 AM
09/21/14 02:06 AM
Yes. CarQuest has a victor reinz #JV551 (iirc on the number) that'll woork for SB/BB
Re: Small block rope rear main seal [Re: RapidRobert] #1674582
09/21/14 07:48 AM
09/21/14 07:48 AM
western australia
1cuda Offline
1cuda  Offline
western australia
i just ordered that big block one for a 273 i`m about to final assembly. cut it the right length and make sure the part line isn`t horizontal like the main cap.
all the best
frank.
Re: Small block rope rear main seal [Re: 1cuda] #1674583
09/21/14 11:59 AM
09/21/14 11:59 AM
On a prior post/thread way back a guy said he cut it a hair long on the ends then folded the threads back in to the center plus a slight offset as mentioned & it kept his dry as a bone. Also iirc he put a drop of RTV on each end junction also. The Victor Reinz kit gives you a big tube of it. EDIT & RTV under the seal in the block/cap halves & roll the seal down in the groove with a socket
Re: Small block rope rear main seal [Re: RapidRobert] #1674584
09/21/14 12:31 PM
09/21/14 12:31 PM
Ontario, Canada
D149 Offline OP
D149  Offline OP
Ontario, Canada
Thanks guys. That is what I needed to know.
1999 Dakota R/T
2000 Viper GTS
