Wiper arms stop straight up. #1674455
09/20/14 12:10 PM
09/20/14 12:10 PM
lapeer, mi.
rtjerry Offline OP
rtjerry  Offline OP
lapeer, mi.
Hi, 67 Coronet R/T 2 speed wiper motor stops in the up position when turned off. What could cause this?
P.S Also the stock air cleaner base has a small opening for carb. I replaced carb with a Eddy 750 now need larger opening for new carb. Are there any bases that will fit the original top about 18"DIA.
Thanks Jerry
Re: Wiper arms stop straight up. [Re: rtjerry] #1674456
09/20/14 01:28 PM
09/20/14 01:28 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Did you have it apart?
Wiper cam installed 180* out is all I can think of. Thats if it always "parks" at the same full up position.
Re: Wiper arms stop straight up. [Re: rtjerry] #1674457
09/20/14 01:58 PM
09/20/14 01:58 PM
lapeer, mi.
rtjerry Offline OP
rtjerry  Offline OP
lapeer, mi.
It has been apart not from me. What exactly is the wiper cam? Is it attached to the wiper motor?
Re: Wiper arms stop straight up. [Re: rtjerry] #1674458
09/20/14 02:42 PM
09/20/14 02:42 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Agree if it follows the same "sweep" and parks at same spot, it may just be a matter of taking the nut off and flipping the arm 180 degrees and re-fastening.
Re: Wiper arms stop straight up. [Re: rtjerry] #1674459
09/20/14 03:50 PM
09/20/14 03:50 PM
Its the small lever arm attached to the wiper motor shaft. The wiper linkage attaches to and pivots on it.
Should look something like...
(photo blatantly stolen from the interwebs )
Re: Wiper arms stop straight up. [Re: nomore65BelvJim] #1674460
09/20/14 03:55 PM
09/20/14 03:55 PM
Might be this exact one...
Re: Wiper arms stop straight up. [Re: nomore65BelvJim] #1674461
09/20/14 10:25 PM
09/20/14 10:25 PM
lapeer, mi.
rtjerry Offline OP
rtjerry  Offline OP
lapeer, mi.
Thanks Guys, I will take it apart tomorrow to try. It makes sence.
Re: Wiper arms stop straight up. [Re: rtjerry] #1674462
09/20/14 11:20 PM
09/20/14 11:20 PM
Tennessee
WyleECoyote Offline
WyleECoyote  Offline
Tennessee
Check the ground. Run a jumper ground to the motor.
Re: Wiper arms stop straight up. [Re: WyleECoyote] #1674463
09/21/14 02:05 PM
09/21/14 02:05 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Pictures!! The switch plate may be clocked wrong
NS1AAR
Re: Wiper arms stop straight up. [Re: ns1aar] #1674464
09/22/14 09:58 AM
09/22/14 09:58 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
Yes to the air cleaner base question.. Had the same problem with mine, found a base at a wrecking yard that worked with mine.. Seems as if alot of the bases are interchangeable..
