Page 2 of 3 1 2 3
Re: Small Block Timing Chain Cover Help Needed [Re: 408strokerdart] #1674374
09/22/14 01:27 AM
09/22/14 01:27 AM
HR3128 Offline OP
HR3128  Offline OP
Is this how it's assembled? The bolt for the lower hole goes thru the pump flange, motor plate, cover into the block. Upper bolt goes thru the cover into the block(countersunk below the motor plate). Another upper bolt goes thru the pump flange, motor plate, into the cover.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674375
09/22/14 01:56 AM
09/22/14 01:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Correct
EDIT
the 4 water pump bolts go all the way to the block
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674376
09/22/14 02:33 AM
09/22/14 02:33 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
EDIT
Nope.... the countersunk bolt goes into the block, and only two of the waterpump bolts go through to the block. The other two thread into the cover.
This was after I had the hole welded into the cover and filed flat so my Mezier waterpump for a standard LA motor would seal to the cover.
Re: Small Block Timing Chain Cover Help Needed [Re: J_BODY] #1674377
09/22/14 03:20 AM
09/22/14 03:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
EDIT
On my 9.2 R3 and the sand cast cover all 4 bolts in
the pump go all the way to the block... I have 4 studs
in it.. in this pic the top were bolts.. I later changed
to studs
EDIT
now you have me wondering but all 4 studs were the
same length
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674378
09/22/14 11:54 AM
09/22/14 11:54 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
your top "water pump" fastner is a bolt....it threads into the timing cover. the countersunk bolt, covered by the motorplate, and the lower waterpump hole "where stud is" thread into the block.
Re: Small Block Timing Chain Cover Help Needed [Re: J_BODY] #1674379
09/22/14 03:02 PM
09/22/14 03:02 PM
HR3128 Offline OP
HR3128  Offline OP
That clears up things a bunch. I was concerned about buying the wrong stuff. That means the motor plate I have will work.
Thanks for the help.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674380
09/22/14 11:33 PM
09/22/14 11:33 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Yep! My biggest hurdle was the belt drive.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674381
09/23/14 12:18 AM
09/23/14 12:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry for the error... I sold my engine and couldnt
go look at it.. I had to go by memory and I guess
thats not working
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674382
09/23/14 12:52 AM
09/23/14 12:52 AM
HR3128 Offline OP
HR3128  Offline OP
thats not working
No problem. If you can give that memory another try, I would like to know where you got the V-belt pulley & dry sump belt drive set-up. That's the next piece to my puzzle.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674383
09/23/14 01:14 AM
09/23/14 01:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
No problem there... I made the V-belt pulley and I
bought the drive for the dry sump from
http://www.cvproducts.com
Your gonna have issues with a couple other things
like the intake valley cover(I made mine) and the
water system that attaches to the heads.. I made that also
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674384
09/23/14 01:18 AM
09/23/14 01:18 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I was able to buy a valley cover from Kent Ritter.
Re: Small Block Timing Chain Cover Help Needed [Re: 340Cuda] #1674385
09/23/14 01:40 AM
09/23/14 01:40 AM
HR3128 Offline OP
HR3128  Offline OP
This is what I have. Valley cover & oil pump were included with the motor. Water fittings are in the heads. Front cover & balancer were not. I have some work ahead to get this all put together.
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674386
09/23/14 01:43 AM
09/23/14 01:43 AM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
I run this on my R3 Motor. Works well. Got it from stock car products
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674387
09/23/14 02:21 AM
09/23/14 02:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah you have the fittings in the heads but are you
gonna run braided line to all them and what will the
other ends hook up to... I made 2 manifolds that
mounted to the head fittings then they have 2 short
lengths of braided that go to the tank that has the
radiator cap on it... plus I needed something up
high(my radiator mounts low) so the air gets out the
top easy
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674388
09/23/14 03:07 AM
09/23/14 03:07 AM
HR3128 Offline OP
HR3128  Offline OP
I was thinking I would get a hose-to-AN adapter for the radiator & run some water lines. The rad has a cap but I'm not sure if it's tall enough to let the air out. Any pics of your set-up?
I have been kind of obsessed with this front cover stuff. I did not know about the special covers for R3 blocks. And without the parts I did not see how it all fit. And did not want to spend $400 on a cover & then find out I bought the wrong one. I was concerned that the motor plate would not fit.
Thanks to all that explained how this stuff bolts together.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674389
09/23/14 10:39 AM
09/23/14 10:39 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I got my valley cover along with some other odds and ends , and some great tips from Ryan J at Shady Dell.
Brett is an awesome source for info on these , but I've yet to pester him for parts.
Ritter- Weber still has some stuff and sometimes get around to making more , but my dealings with them left me with the impression that they'd prefer you know what you need and order accordingly.
Understandable too.........the huge number of ways to skin the R-3 / W-9 cat leaves a lot of room for interpretation.
Between deck heights , valve angles , cam bearings and etc. etc. , You can take as many steps backward as forward while you are sorting things out and some of them have price tags , some only man hours.
But they are unique little beasts and I am really enjoying mine now.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674390
09/23/14 10:40 AM
09/23/14 10:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Here is a pic of how I did the water
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674391
09/23/14 10:43 AM
09/23/14 10:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The manifold
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674392
09/23/14 11:56 AM
09/23/14 11:56 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
408strokerdart (Brian) also made a water manifold for these iirc. you might contact him.
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674393
09/23/14 11:58 AM
09/23/14 11:58 AM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Can I ask a stupid question since I actually will be dealing with some of what has been talked about? I know there are some different deck heights for the R3 blocks. What are they and for some reason I can't remember what the deck height is for a stock 360 block anymore. Anyone? Thanks and sorry for my horrible memory.
Back in the swing of things at Painless again! Great to be back!
Page 2 of 3 1 2 3
