Page 1 of 3 1 2 3
540 Low Deck with 440-1 345CNC Dyno Results #1674148
09/19/14 01:32 PM
09/19/14 01:32 PM
Farmington Hills, Mich
Chuck@Best_Machine Offline OP
Here is a nice Street / Strip 540 we just finished
Indy Alum Low Deck Block
Indy 440-1 345CNC Heads, Reworked by us
Indy 400-2 4150 Intake
Quick Fuel 1050 4150
1” HVH Spacer
280ish at .050 Solid Flat Tappet
T&D Single Shaft Rockers 1.6 / 1.6
Pushrod Oiled
Race Tec12.5 to 1 Comp Pistons .043/.043
Compstar 6.535 Rods
K1 4.250 Crank
Roll Master Timing Chain
Charlie’s Oil Pan
Milodon Single Line Oil System
Dyno Video
https://www.facebook.com/video.php?v=721...e=2&theater
Pictures of Build
https://www.facebook.com/media/set/?set=a.709748919080794.1073741846.135175363204822&type=3
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Chuck@Best_Machine] #1674149
09/19/14 01:33 PM
09/19/14 01:33 PM
2
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Chuck@Best_Machine] #1674150
09/19/14 01:35 PM
09/19/14 01:35 PM
warren, mich.
dwayne welder Offline
warren, mich.
What's it like from, 3000 to 5500????
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: dwayne welder] #1674151
09/19/14 01:46 PM
09/19/14 01:46 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
And curious about the leaner that normal afr`s......... Bad azz hombre though.
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Thumperdart] #1674152
09/19/14 02:19 PM
09/19/14 02:19 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Chuck.........
Any chance you can post the results of Joe's W5 on the pump after you have it on there? Looking forward to seeing how it does with the new heads on it.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Chuck@Best_Machine] #1674153
09/19/14 03:19 PM
09/19/14 03:19 PM
Cab_Burge Online work
Cab_Burge  Online Work
This is living proof on how much power a pump gas motor can make with decent parts What bore and stroke did you use on this build? It looked like the motor wasn't done making power at 7000 RPM I normally pull the motors until I find peak HP
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Cab_Burge] #1674154
09/19/14 03:26 PM
09/19/14 03:26 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I see VP110 listed on the dyno sheet so that's NOT pump gas.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: pittsburghracer] #1674155
09/19/14 03:56 PM
09/19/14 03:56 PM
Oops, your correct
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Chuck@Best_Machine] #1674156
09/19/14 04:12 PM
09/19/14 04:12 PM
oh
julian2007 Offline
julian2007  Offline
oh
quit playing on the internet and call me back, I want to spend some money that's not mine
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Chuck@Best_Machine] #1674157
09/19/14 04:29 PM
09/19/14 04:29 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
1” HVH Spacer
Pushrod Oiled
Compstar 6.535 Rods
K1 4.250 Crank
Charlie’s Oil Pan
Please tell me that part about it having a Flat Tappet cam is a misprint! Why would someone build an engine with all the rest of the parts listed above, yet not run a roller?
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: PorkyPig] #1674158
09/19/14 06:43 PM
09/19/14 06:43 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Out of interest, did you try different carbs or spacers ?
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Thumperdart] #1674159
09/19/14 06:53 PM
09/19/14 06:53 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Maybe that what the plugs said the fueling needed to be. O2's are just another tool nothing more.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Chuck@Best_Machine] #1674160
09/19/14 09:28 PM
09/19/14 09:28 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
Wait aren't you worried about spinning it that hard...?
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Wv68charger] #1674161
09/19/14 09:32 PM
09/19/14 09:32 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Very nice reliable build. Should go lot's of mid 9 second passes.
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: Wv68charger] #1674162
09/19/14 10:13 PM
09/19/14 10:13 PM
Arizona
Chris'sBarracuda Offline
Arizona
NO... It's an aftermarket Low Deck Indy Block..
Don't know if you were being sarcastic or not..
Chris..
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: PorkyPig] #1674163
09/19/14 11:19 PM
09/19/14 11:19 PM
toronto
6PAK70CUDA Offline
6PAK70CUDA  Offline
toronto
Maybe so they don't have to change valve springs as often? Depends how much "street" is in the street/strip.
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: 6PAK70CUDA] #1674164
09/20/14 12:28 AM
09/20/14 12:28 AM
fullmetaljacket Offline
They built me a flat tappet motor just for that, mostly street, some strip tease. No springs needed yet.
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: fullmetaljacket] #1674165
09/20/14 01:11 AM
09/20/14 01:11 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Nice build Chuck
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: poppaj] #1674166
09/20/14 01:18 AM
09/20/14 01:18 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I don't know about Best but I always start pulls on 110 octane or better until I get the tune right. A dyno pulls a motor harder than any car or racer can ever imagine. If you're off just a little you can push a head gasket or blow a piston in the blink of an eye. Better safe than sorry.Dave
Re: 540 Low Deck with 440-1 345CNC Dyno Results [Re: quickd100] #1674167
09/20/14 09:33 AM
09/20/14 09:33 AM
gregsdart Offline
gregsdart  Offline
That's pretty stout for pump gas compression and a flat tappet! IMHO That would make a great bracket engine as well. Change oil and plugs and check the lash in the spring and run it!
Page 1 of 3 1 2 3
