Re: Mopars at the Valley - 20 Sept 2014
[Re: syleng1]
#1673628
09/18/14 10:13 PM
09/18/14 10:13 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
If heading east (from Albany direction) on US20 the racers entrance will be the 1st entrance on the left (by the circle track). If you miss that, then go to the main gate (about 1/4 mile car show entrance) and go in there and turnaround. They pay attention on inspection: catch can for rad. overflow and it doesn't have to be real complicated. Hub caps off. Factory seat belts are fine unless have a roll bar (11.50). I don't remember time when a jacket is required. I don't think they'll even see the holes, not that that would matter. Sounds like you're good to go
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: 340KID]
#1673632
09/19/14 09:17 AM
09/19/14 09:17 AM
Posts: 765 Franklin CT
syleng1
Franklin CT
From Hebron go north to mass pike west to exit b3 I think, first exit after toll booth, when you get to track pass the main gate on right and go in racer entry just pass the go kart track, you should be ok with tech, just make sure helmet has proper snell rating..
Helmet is all set Snell 2010
I think I will remember as soon as I get there, I just remember passing a lot of wooded roads and a few trash container manufacture companies on my way in. Pretty easy ride if I remember correctly. Thanks for the advice.
[Re: aarmaniac]
#1673633
09/19/14 10:59 AM
09/19/14 10:59 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
copy of the flyer
why a week early this year ?
