Re: All this block talk...
[Re: Eric]
#1672708
09/17/14 07:20 PM
09/17/14 07:20 PM
Posts: 1,089 st.cloud fl
d-150
Smarter than a 5th grader?
st.cloud fl
[Re: Eric]
#1672712
09/17/14 08:10 PM
09/17/14 08:10 PM
Posts: 12,408 Taxes & Virus's R-US, NY
Dragula
It was a surprisingly simple question that seemed to ignite the debate in the other thread...As many of us on here do, I race on a budget.
If you look at the Gen3 Hemi builds...all those are with the stock block at +700hp. I have seen the new aluminum blocks for sale, but have yet to see any builds with them. And honestly, I would switch to one if they weren't so costly. A stroker kit at $2700 is pretty steep, and at only 392 to 426 cubes, it just doesn't make sense yet...
It would be great if everyone could afford a new $5k block...But the way I look at it, on a good running race engine, eventually something fails...What's really left of it when it does. On the last 5-6 failures I have seen, the block never survives, nor the cam, rods or pistons... And if you sell the race car, its worth pennies on the dollar and everyone low balls you on it.
[Re: Eric]
#1672713
09/17/14 08:21 PM
09/17/14 08:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I think that 4K for a finished block would fly big time and if it was available in a TIMELY manor.. even 2 months would be fine
[Re: EchoSixMike]
#1672714
09/17/14 08:49 PM
09/17/14 08:49 PM
Posts: 3,421 Toronto
mshred
Toronto
I think if you could sell an iron block at 1995 and an aluminum block at 2995, you couldn't keep them in stock. It doesn't need to be some killer piece, just something that'll handle 1000hp and/or a consistent 4.40 bore without driving over the crank or coming out of the restaurant to your car in a puddle of coolant.
I personally don't care if it takes 40 weeks to get, I can plan ahead and I'm not manic/depressive. S/F.....Ken M
I would buy an aftermarket iron block at that price in a heartbeat!
[Re: mshred]
#1672715
09/17/14 09:07 PM
09/17/14 09:07 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
People are so funny.......
What do you think you would get for $1900? You would get a pile of junk. Just be smart with what your doing. Take that extra $1900 and spend it on good light weight parts and you will be shocked with what you can do.
Why do you think a after market block is so much better that a stock block anyways????? Do you remember the first gen Hemi blocks??? Lifters were popping out of those things like popcorn!!
When an engine goes pop how many times is it truly the block at fault?? Run a good main cap, replace your main studs on a regular bases and that will help a tone. I can say I have had faulty MSD units cause more damage than a stock block ever would.
Just be smart and reasonable with what your doing and half of your problems will go away.
[Re: Mopar-Al]
#1672722
09/17/14 11:31 PM
09/17/14 11:31 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Ok folks...since we are all just pipe dreaming...lowdeck or RB?...and I would think we should stick with aluminum but it's up to you all..
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#1672723
09/17/14 11:39 PM
09/17/14 11:39 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Small block!!!
[Re: Eric]
#1672724
09/17/14 11:48 PM
09/17/14 11:48 PM
d-150
st.cloud fl
[Re: justinp61]
#1672725
09/18/14 12:15 AM
09/18/14 12:15 AM
MR_P_BODY
Small block!!!
I'd like to see a alum SB also.. other than the big dollar sprint car block with all its special parts
