Re: E-Body Door Alignment - How do I lift a sagging door?
[Re: skicker]
#1672579
09/17/14 02:13 PM
09/17/14 02:13 PM
Posts: 1,567 Ky
jt4406
Ky
From my experience adjusting the doors on my 70 challenger earlier this spring, you must have ALL hinge to door, and hinge to body bolts TIGHT, before your door is where it is going to be!!! Just my ![](/ubbthreads/images/graemlins/Twocents.gif) Main rule, BE PATIENT jess
Yeah, it's hopped up to over 160...
[Re: Steve Bryant]
#1672583
09/17/14 03:31 PM
09/17/14 03:31 PM
Posts: 1,023 pa.
dan9
pa.
That should get you there. Keep an eye on door to fender gap so you don't chip the paint. Moving the top hinge forward just a little will make a big difference. Good luck, it isn't as hard as it sounds. You may not be able to actually see the heads of the bolts on the inside, you may just have to feel for them.
[Re: Steve Bryant]
#1672584
09/17/14 03:32 PM
09/17/14 03:32 PM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
So if I understand this correctly, I need to remove the kick panel and insulation and I should see some hinge bolts. I also need to loosen the striker. Once I have the door protected and supported then I can start to loosen the bolts (from inside the car behind the kick panel?) leaving one bottom bolt tight. I can probably look at the paint to make sure I have lifted the door the amount needed then crank down the bolts and softly work the door.
Once I am happy with everything, tighten the striker, crank down the bolts tight and reinstall the kick panel.
Sound close?
There are two bolts per hinge on the outside of the body and one per hinge on the inside behind the kick panel. If you have never done this before you need to get some help from someone who is experienced with these doors. Otherwise you will make it worse than when you started. Once you loosen the bolts that door can move in all directions, up, down, top out, bottom out, top in, bottom in, front higher than the back, back higher then the front, etc. etc.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
