Re: Charging System on a 70 Challenger T/A
[Re: jim6346]
#1672545
09/17/14 12:07 PM
09/17/14 12:07 PM
RapidRobert
I didn't know an alt could put out that kind of voltage & it ain't makin sense that the alt is functioning (even at that high rate) but the batt is showing no charge. 2 field terminal alt/flat reg system I'm assuming. As you know either the alt is bad or the reg is or the green wire circuit from alt to reg is grounded which full fields it. You might pull the wire connectors off of the alt male field terminals and ohm the male terminals to ground and you want no continuity and ohm em to them selves & post what you get. With some jumper wires with alligator clips you could pull the present wiring and jump from batt to reg top terminal/either alt field terminal/jump from other alt field terminal to "side" reg nub terminal (the green wire circuit). jump from alt case and reg case to batt neg which'd take the wiring out of the equation & only leave the alt or the reg. I still ain't grasping the high voltage as when an alt is full fielded either for testing purposes or when bad it is 15+ volts. do a visual on the brushes/brush holders. Holler how it turns out.
[Re: Andrewh]
#1672552
09/17/14 06:37 PM
09/17/14 06:37 PM
Posts: 36 Dulles, VA
phathemi
Dulles, VA
I had similar problem and it was the wiring harness connector block at the firewall melted the wire from the alternator into the car. The old cars didn't have heavy need for amperage (radios, etc.), so they thought it was safe to run power from the alternator into the cabin, then through the ammeter and back through the firewall and to the battery. Our cars were rolling fire hazards, particularly if you put in a real stereo or any option that draws power into the cabin. The short term fix is to jump the block with a side wire, or you can bypass the cabin with the charge altogether but you loose your ammeter (but who cares). The modern fix is to change the ammeter for a voltmeter (dash gauge refresh) and bypass the cabin with the high amp charging, just send the wire right to the battery from the alternator. One of the forums had a document with wiring on how to do this. Good luck, can be very frustrating, but the charging system is simple. It's most likely not your alternator if it's putting out that voltage.
[Re: 383man]
#1672554
09/18/14 03:21 PM
09/18/14 03:21 PM
Posts: 1,546 Seattle, WA
375inStroke
Special needs person
Seattle, WA
What are the voltages at both fields with the car running, and not? What are the voltages at both terminals of the regulator both running and not? The regulator senses voltage at the I terminal, which should be the same as what is at the field terminal with the blue/white trace wire. It then modulates the resistance to ground at the F terminal, causing the field of the alternator to increase when voltage drops, or decrease when the voltage increases above the designed voltage. As you can see from the diagram, the output of the alternator, if it is 35 volts, should be going through the ignition switch, to the terminal on the ballast resistor, and to the I terminal on the regulator. The regulator should be increasing the resistance at the F terminal, lowering the magnetic field created in the alternator, dropping voltage till it reaches around 14.whatever volts. Is there 35 volts at the I terminal when running? ![](http://www.mymopar.com/downloads/Dual_Field_Alternator_Wiring.jpg)
[Re: 383man]
#1672555
09/18/14 04:35 PM
09/18/14 04:35 PM
Posts: 559 Newark Valley, NY
jim6346
Newark Valley, NY
Changing the alternator fixed the problem, but I am still confused. I was still measuring around +30V at the post, but was getting +13.8V at the battery. When I shut the car off, I was getting 12.5V at the battery.
Amp Meter was about 3/4 way up the positive side, then gradually went back down.
Forgot to mention, this has electronic ignition, not sure if that has anything to do with it.
Anyway, customer is happy!!
Thanks everyone, Jim
[Re: jim6346]
#1672556
09/18/14 06:11 PM
09/18/14 06:11 PM
RapidRobert
(1) me too (2) I cant see the alt puttin out 30+ volts & if it did you'd see (near) that at the batt unless that circuit (alt around to batt) is open & it ain't (wrong scale on the meter possibly?). (3) iirc ~12.5V is a nomally charged batt/eng off. (4) alt needle returned to normal (12 0'clock) as the batt got charged (from being discharged from the non functioning alt) (5) electronic ign is unrelated (6) if the customer is happy I'm happy ![](/ubbthreads/images/graemlins/thumbs.gif)
