custom shock length with relocated leafsprings.??
#1672351
09/16/14 06:17 PM
09/16/14 06:17 PM
Posts: 202 Barboursville, VA
belvedere383
Barboursville, VA
I recently did the mini tub and moved the leaf springs inboard on my 65' Belvedere. I ordered the springs -1 inch ride height and have a 1/2 inch lowering spacer installed. With the factory dimension shocks it only left me with maybe 1 inch of usable travel.
My question is do you have to order custom shocks for the application or do Strange, Afco, or QA1 sell something that will fit?
65' Belvedere
496'' Stroker Indy Heads
Re: custom shock length with relocated leafsprings.??
[Re: belvedere383]
#1672352
09/16/14 06:41 PM
09/16/14 06:41 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I am cheap, so I went with the Calvert (Rancho) single adjustables...called them, told them my static, extended and compressed heights, they sent me shocks....
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#1672353
09/16/14 06:43 PM
09/16/14 06:43 PM
belvedere383
Barboursville, VA
That doesn't sound like a bad idea, I would really like to have a set of double adjustables for this build.
65' Belvedere
[Re: MR_P_BODY]
#1672355
09/16/14 07:00 PM
09/16/14 07:00 PM
belvedere383
Barboursville, VA
I had the ranchos on it when it ran that number a few years ago. Since then I have done a few suspension mods, put an auto in it, changed the rear to a 9 in, changed camshaft and ported heads and added a plate kit to it. Would the single adjustable still suffice for me ?(serious question not trying to be smart)
65' Belvedere
[Re: belvedere383]
#1672356
09/16/14 07:13 PM
09/16/14 07:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Probably not due to you making more power and the spray.. a lot of guys running them are right at the max setting so it doesnt leave anything left for adjusting... you would be better off with some quality shocks ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1672357
09/16/14 07:26 PM
09/16/14 07:26 PM
belvedere383
Barboursville, VA
OK well I will call afco or qa1 tomorrow and see what they have to say.
Thanks for the info.
65' Belvedere
[Re: belvedere383]
#1672358
09/17/14 01:11 AM
09/17/14 01:11 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I recently purchased a set of Vi-king double adjustable shocks. Also will change the front top mount to eliminate the shock stud that comes into the engine compartment. Worked with Chris to determine the dimentions I needed up front,and added the more aggressive valving for the rear. I believe gains could be seen even with cars in the 11's ![](/ubbthreads/images/graemlins/image_294343.gif)
