Champion Wheel anyone use them?
#1672182
09/16/14 01:11 PM
09/16/14 01:11 PM
Posts: 625 Indianapolis In. usa
Quickrunner
Anyone use Champion Wheel billet racing wheels? They look nice and have decent price for bead lock rears. Any experience with them good or bad?
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Champion Wheel anyone use them?
[Re: GY3]
#1672184
09/16/14 01:43 PM
09/16/14 01:43 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
Have ordered a few sets. Had a ordering issue once that was taken care of. They are very nice wheels for the price just a little on the heavy side if your use to weld magnums/ 2.0 etc.
One day I will have something cool here.
[Re: Quickrunner]
#1672186
09/16/14 02:24 PM
09/16/14 02:24 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
If you are thinking of double bead locks make sure that you check with them. They use a small drum so there has been many issues with brake to wheel clearance with them. Other than that they are really a nice (heavier) wheel and the people up there are pretty good people. If you have a question they will do what they can to answer them.
Back in the swing of things at Painless again! Great to be back!
[Re: Quickrunner]
#1672187
09/16/14 07:29 PM
09/16/14 07:29 PM
Posts: 5,894 Florida
Locomotion
Have you considered Holeshot Wheels? They are available with beadlocks, lots of brake clearance, fronts are available in 1 piece billet, many style options and they can make many custom adjustments if needed. They are pretty light, but still strong. I've had them on my cars for many, many years. Great reputation and customer service. Holeshot Wheels
[Re: Locomotion]
#1672188
09/16/14 07:47 PM
09/16/14 07:47 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
I LOVE those Mickey pro 5 wheels. They are sweet!!!!
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: bigtimeauto]
#1672190
09/16/14 10:49 PM
09/16/14 10:49 PM
Quickrunner
I like the mickeys also but don't see the new ones with small backspacing like I want on a 12 inch rim. I had a set of the previous version on my roadrunner and loved them.
[Re: Quickrunner]
#1672191
09/17/14 12:28 AM
09/17/14 12:28 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I had a good buying experience with them. The only issue was the front wheel hit the caliper.Needed a .400 spacer to clear the caliper. When you look at all the different wheels,all the attention is on the rear hoop. The fronts are available in 2 backspace choices. The way the spoke is,it wouldn't matter with the backspace. Since they make wheels to order,I could have maybe had them build a rim with a .400 thicker mounting pad.
