Page 6 of 8 1 2 3 4 5 6 7 8
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 72Swinger] #1671632
10/31/14 11:21 AM
10/31/14 11:21 AM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
How did you do Tom? That thing should be on rails! Or those tires the Super Sports or Ventus? Also what is your front camber?
The car is really coming alive on the Hankook R-S3s, it turns in beautifully. Camber is 2.75. At the Hotchkis Autocross on Saturday I finished 5th out of 20 cars in the old car class. The gearing with the A833 OD hurts it at times, 1st is too low, 2nd is too tall. Hotchkis Dan got in and turned a lap that was good enough for 3rd, behind only a 1964 Corvette body that was mounted on a new ZR1 chassis/engine and the TCI Camaro.
On Sunday finished 3rd out of 12, again losing to cars with a lot more gears and HP...
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Tomswheels] #1671633
10/31/14 01:26 PM
10/31/14 01:26 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
So any other stock suspension cars were in the dust basically.
Mopar to the bone!!!
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Tomswheels] #1671634
11/01/14 12:40 AM
11/01/14 12:40 AM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
Any temp data? RS3v2 REALLY starts working at 120F ;-) 2.75^ is surprising. I'm just now started to turn my a-body. For reference I use less than that on my mc-strut g-street FWD.
What is your suspension setup Tom?
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Trojmn] #1671635
11/01/14 01:25 AM
11/01/14 01:25 AM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
All Hotchkis TVS, Fox adjustables. It was definitely cooler Sunday, could have used more temp! [image][/image]
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Tomswheels] #1671636
11/02/14 01:29 PM
11/02/14 01:29 PM
omahell, ne
buconine Offline
buconine  Offline
omahell, ne
Sorry if i missed it on an earlier post.
What is the rear setup on your valiant? Minitub or offset shackles? Really like the look with the 285's. Any front fender clearance issues with the big tires in the fronts? Getting ready to start ordering parts for mine and am planning a similar wheel size and suspension setup. Thanks!
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: buconine] #1671637
11/02/14 03:19 PM
11/02/14 03:19 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
I don't recall if he has offset shackles, but his fenders are flared, subtly.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: buconine] #1671638
11/02/14 04:07 PM
11/02/14 04:07 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
Samy is correct, stock rear spring location, no tubs. Front and rear fenders pushed out to fit 285 tires on 10 inch wheels. I'm trying 305 on 19x10.5 rims in the rear this week...
[image][/image]
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Tomswheels] #1671639
11/02/14 09:40 PM
11/02/14 09:40 PM
omahell, ne
buconine Offline
buconine  Offline
omahell, ne
I think i saw the thread on cutting and portapowering the 1/4's. I'm out on that one, way out of my skill level. Guess i'm back to the can i fit 275/35r18's with just offset perches quest...
Thanks for the info! Your car looks amazing with the big tires on it.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Tomswheels] #1671640
11/21/14 02:11 AM
11/21/14 02:11 AM
SoCal
SoCal
Found the Enkei RP03's (18x9, +40mm and +18mm offsets) online for the cheapest price I could find them for from what seems to be a very good vendor (great online reviews). If the +18mm are still too close to the leaf springs (which I don't think it will), then I'll add a spacer (was trying to get the smallest spacer possible). I'm just curious if I should make the purchase now so they'll be here by the time I finish finals in 3 weeks.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671641
11/21/14 02:28 AM
11/21/14 02:28 AM
Plano, Texas
68cuda440 Offline
68cuda440  Offline
Plano, Texas
Nobody makes a 255/40/18 in an "Extreme Performance Summer" tire except Yokohama. Lame.
Tire is RT615k 255/40-18; front wheel is SVE Drift sold by Late Model Restoration 18x9 ($150 each), 6.38" Backspacing (for a 2005-2014 Mustang)
-Michael
Michael 1968 Barracuda Notchback Coupe 440 EFI 6-pack, T56 Magnum 6-spd
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 68cuda440] #1671642
11/21/14 02:36 AM
11/21/14 02:36 AM
SoCal
SoCal
-Michael
I found out Michelin Super Sports come in a 255/40/18. It definitely looks good. The wheels that I'm looking into purchasing seem to have backspacing of about 6.6" which is about +6mm more offset than yours. Luckily, we both have the same front brake package.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Tomswheels] #1671643
11/21/14 10:12 PM
11/21/14 10:12 PM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
damn this thread!!!! i need more tire ;-)
CAM-T PAX =0.825
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Trojmn] #1671644
11/21/14 10:46 PM
11/21/14 10:46 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
Yes you do! Tightened the rear sway bar, and went up to 305/30 tires on 19x10.5 wheels. Rear end was much better, won my first CAM race this year...
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Tomswheels] #1671645
11/22/14 11:59 AM
11/22/14 11:59 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Congrats!!! Thats awesome man
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: Uhcoog1] #1671646
11/22/14 10:41 PM
11/22/14 10:41 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
Thanks! It's always fun winning in the only Mopar!
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671647
11/24/14 12:53 AM
11/24/14 12:53 AM
SoCal
SoCal
I just placed my order on wheels. I'm wondering if I should order 245/40/18's and start by there or just stick with the 255/40/18's and fiddle around. Remeasuring, I think I'm going to need some small spacers but as long as I have good thread engagement, I think I should be fine. I can't afford to have the wheel hit the frame rails due to brake lines.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671648
11/24/14 12:59 AM
11/24/14 12:59 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
What wheels? Don't be holding out on us now, I would definitely go with the 255's.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 72Swinger] #1671649
11/24/14 01:03 AM
11/24/14 01:03 AM
SoCal
SoCal
The same ones I've been talking about. Enkei RP03's, 18 x 9's, +40mm for the front, +18mm for the rears. I think I may need +5mm spacers up front and maybe a tiny one out back. From my measurements on the rear, the new wheels will put the tire about 0.400" away from the leaf springs, so a super skinny guy just to move things out a little bit shouldn't hurt too much. We'll see when I mock them up.
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: MuuMuu101] #1671650
11/24/14 01:08 AM
11/24/14 01:08 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Awesome those will look good! I thought Enkei made those with a 35mm bs also?
Re: 275 Series Tires, A-bodies, and Offset Shackles [Re: 72Swinger] #1671651
11/24/14 01:15 AM
11/24/14 01:15 AM
SoCal
SoCal
They did in an 8.5" wide wheel. The good thing about these wheels is that their going to weigh about 18.3 lbs a piece. They're cast, I believe, but they're made out of an aircraft grade aluminum. I'm curious how they're going to look as all of the pictures I've seen of them were on lowered and super-cambered imports. Attached is all the specs on the RP03's.
8340200-RP03.pdf (124 downloads)
