Rear tires wearing out on inside? Both tires #1671420
09/15/14 04:26 PM
09/15/14 04:26 PM
dogdays Offline OP
dogdays  Offline OP
So I had really nice tires on the rear of the '64Dog and after about 10,000 miles I noticed the insides of the tires are wearing off. Anyone ever had that happen? Rear end is 8 3/4 out of a '71 D100.
My guess is the housing is bent, looks like it's toed out a bunch. I haven't measured yet. Any other guesses?
R.
Re: Rear tires wearing out on inside? Both tires [Re: dogdays] #1671421
09/15/14 05:17 PM
09/15/14 05:17 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Its either alignment/bent housing or tires starting to separate.
Re: Rear tires wearing out on inside? Both tires [Re: NITROUSN] #1671422
09/16/14 12:43 PM
09/16/14 12:43 PM
cleveland, tx
dodgzilla 1 Offline
dodgzilla 1  Offline
cleveland, tx
i hadthe same problem. in my case is a heavy foot on the gas pedal and the other foot on the brake.
Re: Rear tires wearing out on inside? Both tires [Re: dogdays] #1671423
09/16/14 08:26 PM
09/16/14 08:26 PM
Truckville, the capital of NY
85_Ram_4speed Offline
Probably bent housing. I had a housing in my Dartsport that bent from the u-bolts out on both sides and had the same tire wear as you. Ate up a set of expensive DOT Hoosiers.
Outcast Dodge guy.
