Re: "PLYMOUTH" badge on 71 Cuda Shaker hood...
[Re: 71redcuda]
#1671408
09/17/14 01:14 AM
09/17/14 01:14 AM
Posts: 4,784 Ontario, Canada
mccannix
Ontario, Canada
Hello,
Is it possible that a 71 cuda could come with a shaker hood w/o the badge if it was a early built car?
THANKS Nicklas
That could be possible, but then the hood underside should also have no stress reliefs.
[Re: mccannix]
#1671409
09/17/14 02:08 AM
09/17/14 02:08 AM
Posts: 1,551 Sweden
71redcuda
Sweden
Hello,
THANKS Nicklas
Ok, thanks for the info.
[Re: 71redcuda]
#1671410
09/17/14 03:18 AM
09/17/14 03:18 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Kind of hard to tell but this early promo vid from 1971 appears to have no Plymouth hood emblem? Mike http://youtu.be/vezBAOe-HKY
[Re: B5cudavert]
#1671414
09/17/14 04:21 PM
09/17/14 04:21 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
Just look under the hood in the area were the emblem would be. There will b 3 circles about 3/4 in diameter in the under bracing. the emblem gets placed thru the hood. A sheet metal nut would be up against the hood skin in that area ,not thru both layers. if your hood was not drilled & you have the reliefs in the underbracing , then you had no emblem.( wich is very odd & rare) 71 emblems have pins that go thru the hood.
As a side note ,AMD forgot to put those relief holes in the under brace on their Cuda shaker hoods. Another problem with repro stuff-its never exact!
Early '71 hoods did NOT have the reliefs in the understructure of the hood as they were leftover '70 hoods that had no need for them. Most '71 SHAKER hood 'Cudas also do NOT have the reliefs as they also are non-crush zone left over '70 style hoods.
[Re: LVSRT10]
#1671418
09/21/14 12:22 AM
09/21/14 12:22 AM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I know of a 1971 Cuda build date of 926 shaker hood that has no crush zones but does have the Plymouth on the front of the hood. This car has been repainted and when I get to see it in person I will see if there are holes in the hood for the Plymouth. I guess I will did out my Nov 5th built Cuda with the shaker hood and see if the hood has the holes or not for the plymouth. It is a crush zone hood.
1971 HEMI E BODY REGISTRY
