Re: Can't find any info on a block casting #
[Re: Leigh]
#1671089
09/15/14 01:05 AM
09/15/14 01:05 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Year?..if it's any good? Sonic checked very good for what it's worth.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#1671090
09/15/14 01:13 AM
09/15/14 01:13 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Eric .. if you have the Mopar big engine book it'll tell you the year(mine is out in the shop) but it wont tell you anything other than that.. if it sonic checks good then I would think its a good block
[Re: Eric]
#1671091
09/15/14 01:39 AM
09/15/14 01:39 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
The last number 5 does mean its on its 5th casting, that doesn't mean its bad. For the year, its cast right into the block right below the casting numbers on the drivers side at the rear of the block below the heads on your engine block. Other years , its on the passenger side.
But with your numbers as posted it should be on the driver side. Reguardless, the year stamping numbers will be cast into the block. Look , both sides. Should be very visable, but maybe not super readable.
