Plug reading ? #1671050
09/14/14 10:01 PM
09/14/14 10:01 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Could someone read/decifer my spark plug. Its a Autolite 3924.
Re: Plug reading ? [Re: 493RT] #1671051
09/14/14 11:09 PM
09/14/14 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I can say one thing... you have too much timing
Re: Plug reading ? [Re: MR_P_BODY] #1671052
09/14/14 11:36 PM
09/14/14 11:36 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Thanks Mr.P , I just switched to a bigger 950 Holley carb, had a thremoquad on it before and it pinged like crazy. I should probably put new plugs in it and it check it then. Is the autolite 3924 a good plug to run . This is on my 493 with edelbrock performer RPM heads ?.I was thinking my timing is at 37 deg. total . Also running 110 octane. Thanks for the feedback
Re: Plug reading ? [Re: 493RT] #1671053
09/14/14 11:54 PM
09/14/14 11:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm running that plug in my SB at 10.4:1
Re: Plug reading ? [Re: MR_P_BODY] #1671054
09/15/14 12:12 AM
09/15/14 12:12 AM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Ok , thanks. I'll get some new plugs and back the timing down a couple degrees . Thanks again, I'm sure I will be back with some more questions.
Re: Plug reading ? [Re: 493RT] #1671055
09/15/14 12:30 AM
09/15/14 12:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It might take a run or two but look for the color to
be in the middle of the bend on the ground strap
Re: Plug reading ? [Re: MR_P_BODY] #1671056
09/15/14 12:27 PM
09/15/14 12:27 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Heres a question, I've seen this on plugs in some engines myself and never knew what to make of it; why does it look "fuzzy?"
Re: Plug reading ? [Re: GTX MATT] #1671057
09/15/14 12:30 PM
09/15/14 12:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most of what your seeing is the fuel additives
Re: Plug reading ? [Re: MR_P_BODY] #1671058
09/15/14 12:32 PM
09/15/14 12:32 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Figures
Re: Plug reading ? [Re: 493RT] #1671059
09/15/14 01:54 PM
09/15/14 01:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s a hot plug for your combo in my opinion...........it`s like a #5 in NGK and the band you see on the ground may move closer to the middle of the ground strap if you go to a # 7............That plug looks hot and nasty. Try a 7, post a pic and see what happens.
Re: Plug reading ? [Re: GTX MATT] #1671060
09/15/14 03:13 PM
09/15/14 03:13 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Figures
Might be a little bit of anti seize towards the end of the threads...
Re: Plug reading ? Updated [Re: Thumperdart] #1671061
09/16/14 10:17 PM
09/16/14 10:17 PM
Mcgregor, Ia
493RT Offline OP
493RT  Offline OP
Mcgregor, Ia
Changed to Autolite 3922 plug. I also left the timing alone. Heres a picture of the 3922 plug
