Page 9 of 16 1 2 7 8 9 10 11 15 16
Re: Time to show your streetrods or rod projects [Re: Hemi Allstate] #167102
09/18/11 11:24 PM
09/18/11 11:24 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
Another pic.
EVERYTHING is looking GREAT!!!!!
Re: Time to show your streetrods or rod projects [Re: Mopar Ron] #167103
09/19/11 06:46 PM
09/19/11 06:46 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Thanks Ron,
Coming from you that means a lot!
I gotta find more pictures to keep that CrAzyMoPaR Guy motivated on his coupe!
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Time to show your streetrods or rod projects [Re: Hemi Allstate] #167104
09/19/11 10:05 PM
09/19/11 10:05 PM
moparx Offline
moparx  Offline
it appears the body has minimal "side to side" reinforcement such as a full attached floor pan would provide. how are you attaching the body to the chassis, and how is the floor attached ? for my humpback, i am wanting the floor panels to plug weld to the chassis with the cage, and then attach the body to the cage in a perimiter[ think vw floor pan] fashion, with the door jams bolted to several tabs welded to the cage main hoop and dash bar to insure door alignment stays in place.
Eric,
We are both trying to achieve the same goals. That part of the build has complicated things a great deal. I have had some good help with that planing, and we will see how it works out.
The body mounts to four points on the chassis at the front and rear of the rockers, and then at the rear crossmember of the frame. The mounts are solid, but there is room for shims if needed. The doors on this car have adjustable (encapsulated) mounting plates that allow me to move the doors quite a bit, probably a much different arrangement than what you are dealing with?
I am planning on the frame mounts pulling the body back into the same shape as before removal.
The floor pans were fabbed to mount to the tops of the frame rails. Originally we were going to plug weld them, but, instead I am using some stainless steel strips to clamp them to the frame with button head bolts. I may also use a very thin two sided tape to try and reduce vibration. I am fairly sure this car will have more than it's share of rattles!
I think that your plan will work Eric, but my opinion is worth what it costs!
Thanks for the kind words. I am really trying to get this thing together.
Mark
well mark, you said a mouthfull when you said it sorta complicates things a little with our thoughts on body mounting. to be a little more specific, at this time i have the body mounted to 4 points at the doors. this is to frame mounts at the front and rear of the door openings at the rocker panels[ more specifically, where the rockers will be when fabbed]. it will also recieve 2 chassis mounts at the bottom of the cowel for the front mounts. at the rear of the body, there will also be 2 chassis mounts at the bottom of the rear door opening. the double rear doors will be welded together and hinged so the door will then open ala mini-van style[using the hinges and latch mechinism from my old 95 caravan. i will also be using the roof panel to fill in the top of the humpback]. the tubs will be welded to the body with flanges to attach to the chassis at [however many] points to be detirmined. the cage attaching points i mentioned will be tabs welded to the door jams at the knee bar/down tubes directly at the latch point, and the main hoop[door pillar post] at both hinge areas[ there were originally 3 hinges per door, but as the height reduction was so severe, the middle hinge was removed]. the remaining area[s] around the firewall and rocker panels will have several bolts[most likely 1/4-20 button heads] attaching that tinwork to the chassis. the center portion of the floor, including the tunnel, will be welded to the chassis. anyway, that's the plan....... geeze a guy hasta thimk SO far ahead....... [ my head is ready to go POOF ! ][gotta get my camera figgered out
your painted chassis REALLY LOOKS GOOD !!!!!
Re: Time to show your streetrods or rod projects [Re: Hemi Allstate] #167105
09/20/11 11:16 PM
09/20/11 11:16 PM
Canada
CrAzYMoPaRGuY Offline
Canada
Thanks Ron,
Mark
MORE THAN YOU KNOW!!!
Stunning is what I think, the engineering, execution, and the overall look/package.... it's a WOW car if I've ever seen one!
I'm sending a pic or two to TopJimmy, see if I can make his heart race....
CrAzYMoPaRGuY
Re: Time to show your streetrods or rod projects [Re: moparx] #167106
09/21/11 12:14 AM
09/21/11 12:14 AM
Mt. Eden Ky.
Mt. Eden Ky.
Eric,
you have obviously given this a lot of thought! It sounds to me that it will be very secure. It's great that you have the doner van for hinges, latch, and roof panel.
I know that many times I would find myself just staring at the car trying visualize the best way to do something. I like the KISS principal wherever possible.
Get that camera working! We need pictures!
Thanks for the positive feedback!I appreciate it!
1996 Ram 1500 Sport
1968 road runner
Re: Time to show your streetrods or rod projects [Re: CrAzYMoPaRGuY] #167107
09/21/11 01:20 AM
09/21/11 01:20 AM
Mt. Eden Ky.
Mt. Eden Ky.
Mark
Thanks Marc, you are too kind!
I will try to find some more pictures to post.
How are things looking for your coupe floors? Are you ready to start on them? This inspiration thing works both ways!
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Time to show your streetrods or rod projects [Re: Hemi Allstate] #167108
09/22/11 02:55 AM
09/22/11 02:55 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
Ha Ha Ha !!!! Don't I wish. I do like that color on the car though. Oh well too late to change now.
Mark
MARK, why to late ?? have you sprayed the car ?
Don, I have already started painting the car. I have finished all floor panels , wheel tubs, etc. and I am spraying the roof and cowl now.
Here is a pic of some finished parts.
Mark
MARK, looks good to me
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Time to show your streetrods or rod projects [Re: 1OFNONE] #167109
09/22/11 02:56 AM
09/22/11 02:56 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
You all may laugh at painting in a dirty ass garage. Not mine by the way.
I cleaned it and hose it and cleaned it and hosed it and cleaned it and hosed it. hey, did I mention I cleaned and hosed it ? LOL
The paint turned out awesome ! I was very happy. People cant belive I painted it without a booth. There is vitually zero dirt. I did have one bug though. I pulled him out before the clear flashed and then the clear flowed back and you cant even see it.
looks great ,,,bugs or no bugs,,
2015 cherokee
2013 R/T classic
Re: Time to show your streetrods or rod projects [Re: Webster] #167110
09/22/11 03:02 AM
09/22/11 03:02 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
Nice job ....I have not seen that since the 70's
all the older styles of paint jobs are comming back,and i love it, i can remember when i was in my 30s thinking what ever happened to custom cars,,chop tops,wild paint, well whats old is new,,i also love panel paint jobs,,wonder if bell bottoms will return ? or the burn the bra movement??lol
2015 cherokee
2013 R/T classic
Re: Time to show your streetrods or rod projects [Re: Hemi Allstate] #167111
09/22/11 03:05 AM
09/22/11 03:05 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
Made some more progress today!
SWEET!!!!! great color,,
2015 cherokee
2013 R/T classic
Re: Time to show your streetrods or rod projects [Re: Mopar Ron] #167112
09/22/11 12:56 PM
09/22/11 12:56 PM
newark oh.
66cnet500 Offline
66cnet500  Offline
newark oh.
My 48
48 plymouth 2 door sedan street rod
65 meyers manx dune buggy
66 coronet 500 (resto project)
77 w200 m880
02 dakota
Re: Time to show your streetrods or rod projects [Re: 66cnet500] #167113
09/22/11 01:09 PM
09/22/11 01:09 PM
newark oh.
66cnet500 Offline
66cnet500  Offline
newark oh.
Another
77 w200 m880
02 dakota
Re: Time to show your streetrods or rod projects [Re: 66cnet500] #167114
09/22/11 01:30 PM
09/22/11 01:30 PM
Nort Cackalacky
rrbrucea Offline
Member known as the "Artist"
rrbrucea  Offline
Nort Cackalacky
My 48
I LIKE that!
What's under the hood?
Re: Time to show your streetrods or rod projects [Re: rrbrucea] #167115
09/22/11 02:58 PM
09/22/11 02:58 PM
newark oh.
66cnet500 Offline
66cnet500  Offline
newark oh.
Thank you, i put a mustang 2 crossmember rack/pinion, 355/350turbo c***y, 8.75 suregrip 355. Original interior one respray long long time ago. Car was copletely orig when i got it in 05, and been a local car since new. I do have plans of swappin over to sbm over winter, a .060 over 360 w/mag heads is 3/4 done at machine shop. Fitment and$ was the deciding factor when built.
77 w200 m880
02 dakota
Re: Time to show your streetrods or rod projects [Re: 66cnet500] #167116
09/22/11 03:28 PM
09/22/11 03:28 PM
Nort Cackalacky
rrbrucea Offline
rrbrucea  Offline
Nort Cackalacky
Okay, it'll be COOLER once the 360 goes in!
Re: Time to show your streetrods or rod projects [Re: fstfish66] #167117
09/23/11 12:30 AM
09/23/11 12:30 AM
Mt. Eden Ky.
Mt. Eden Ky.
Thanks Don,
The car was two toned, (silver over gray) last time, but I decided to go with just silver outside this time. The frame,cage, and dash are a dark gray.Color choice is tough after all these years in primer!
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Time to show your streetrods or rod projects [Re: 66cnet500] #167118
09/25/11 03:41 AM
09/25/11 03:41 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
nice ride, glad to see it will soon be a full fledged mopar and not a slopar,,good luck with the swap,,,and post plenty of pics and info for others,,,thanks
2015 cherokee
2013 R/T classic
Re: Time to show your streetrods or rod projects [Re: Hemi Allstate] #167119
09/25/11 03:44 AM
09/25/11 03:44 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
Thanks Don,
Mark
MARK,, cant wait to see it all painted, silver is a great color on almost any vehicle IMO ,my barracuda was orignally silver,but my first car,a 64 cuda was black,,car has plenty of stainless trim to offset the black,,was almost silver tho,,
2015 cherokee
2013 R/T classic
Re: Time to show your streetrods or rod projects [Re: fstfish66] #167120
09/27/11 09:55 AM
09/27/11 09:55 AM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
MARK... when do you think we can see that work of art ALLSTATE of yours on the road ?? I should send you my junk for paint and body work ..then it will be something ...great car that Allstate..good luck.Larry
Re: Time to show your streetrods or rod projects [Re: dynamite] #167121
09/27/11 04:10 PM
09/27/11 04:10 PM
Mt. Eden Ky.
Mt. Eden Ky.
Hey Larry,
I see that you are still having fun with your Plymouth! Did you get that 11 sec. ET? Your car is looking great just the way it is!!
I was hoping 2011 would be the year for the Allstate. It looks like next year now. I really do think that I can get it done this winter. I sure am going to try anyway.
Thanks for the kind words Larry.
Mark
1996 Ram 1500 Sport
1968 road runner
