Re: spark plug gap 470 stroker
[Re: dangina]
#1670484
09/13/14 01:43 AM
09/13/14 01:43 AM
RapidRobert
With a regular (non MSD) ign I'd start with the tried & true stock gap of .035". You can experiment with 40-45 and even 30 and 25 as Jacobs ign states that a smaller gap can provide a gain in some apps.
[Re: dangina]
#1670486
09/13/14 01:21 PM
09/13/14 01:21 PM
RapidRobert
I'm assuming the rev n nator ain't an MSD type (multispark) ign. I'd start at .035" and get an Echlin NAPA MO3000 rotor which has a .060" longer blade ($8 & change out the door) which will reduce the required voltage (needed if you play with larger plug gaps) as any external gap is a waste and it can help rotor phasing issues (if RP is off)
