Page 2 of 16 1 2 3 4 15 16
Re: Time to show your streetrods or rod projects [Re: Mopar Ron] #166962
12/15/08 07:05 PM
12/15/08 07:05 PM
North East
BobPer Offline
BobPer  Offline
North East
1936 Dodge, slow but sure.
Re: Time to show your streetrods or rod projects [Re: Mopar Ron] #166963
12/15/08 09:25 PM
12/15/08 09:25 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Chopped and sectioned!I thought it had a low profile compared to others I've seen.I myself have a coe,but it's not rod material,it's a '69 Dodge L-600 tilt-cab.Hope to make it a car hauler for my A-100 van
Ron
yes, it's chopped 3 1/2" and its sectioned 4"
it was going to be my radical toy but now its going to be my radical car hauler and the other COE is going to be the toy with the blown 440 thats why I call "IT" radical,radical COE. Ron...
this is another shot of radical,radical.
its sets much lower than the first one
Re: Time to show your streetrods or rod projects [Re: RTSrunner] #166964
12/20/08 01:46 PM
12/20/08 01:46 PM
arizona
leavitt4 Offline
leavitt4  Offline
arizona
heress my newest baby wifes already jelous hahaha
Re: Time to show your streetrods or rod projects [Re: BobPer] #166965
12/20/08 09:28 PM
12/20/08 09:28 PM
arizona
leavitt4 Offline
leavitt4  Offline
arizona
are those fiberglass doors you have on there and if so where did you get em
Re: Time to show your streetrods or rod projects [Re: leavitt4] #166966
12/21/08 11:22 AM
12/21/08 11:22 AM
Iowa
73ChargerSE440 Offline
Iowa
Hey Ron more pics of the radical radical ?
Adam
67 Ply. Belvedere II 2dr Hardtop 73 Dodge Charger SE 440+6 727 Dana 60 4.10 78 Chrysler Cordoba 400-4 727 9 1/4 3.21 1999 Dodge Diesel 2500 QuadCab Longbox 2004 Dodge Durango HEMI Limited
Re: Time to show your streetrods or rod projects [Re: leavitt4] #166967
12/25/08 09:36 AM
12/25/08 09:36 AM
North East
BobPer Offline
BobPer  Offline
North East
Two of my other 36's. This coupe is chopped 2 1/2"
Re: Time to show your streetrods or rod projects [Re: RTSrunner] #166968
12/25/08 06:05 PM
12/25/08 06:05 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Ron
Ron, when you made he front fender inserts to make them smaller, what kind of a lip did you use, flat or rolled?
Re: Time to show your streetrods or rod projects [Re: leavitt4] #166969
12/25/08 10:13 PM
12/25/08 10:13 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
Almost an AMC , almost a mopar -1953 Hudson Hornet club coupe , 5.9 Mag. auto trans.
Re: Time to show your streetrods or rod projects [Re: rowin4] #166970
12/26/08 12:46 AM
12/26/08 12:46 AM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline OP
my neighbor was making a baja bug and he cut up the rear fenders on a VW bug so I took the rolled lip and welded them to the coe front fenders Ron...
Re: Time to show your streetrods or rod projects [Re: Mopar Ron] #166971
12/26/08 10:40 AM
12/26/08 10:40 AM
Kentucky
Flipper1938 Offline
Flipper1938  Offline
Kentucky
Damn! I guessed right!
The trailing side looked really VW to me.
Re: Time to show your streetrods or rod projects [Re: Mopar Ron] #166972
01/05/09 11:08 PM
01/05/09 11:08 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Here's the '46 dodge Im working on. This is a mockup on the frame and yes it will sit way lower.
It' has a 318/904 and an 8.25 rear from a '74 duster.
Re: Time to show your streetrods or rod projects [Re: DusterKrazy] #166973
01/07/09 05:29 PM
01/07/09 05:29 PM
Iowa
Iowa
Hey DusterKrazy, is that a front clip from a duster on the front of the frame?
I have a 41 not sure what drivetrain/running gear I am going to use
Adam
Re: Time to show your streetrods or rod projects [Re: 73ChargerSE440] #166974
01/07/09 06:54 PM
01/07/09 06:54 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Adam
Actually it's the frame from a 1977 dodge d100 pickup that we cut 2ft. out of This seems
to be not a bad route to go as the late 70's dodge trucks are still cheap if you look around for them. Engine mounts are easy as well, already in place and the brake parts are reasonable as well. Good luck with your project!
The cab seems a little wide at first but once we fab up the mounts and get it channeled it will look just right
Re: Time to show your streetrods or rod projects [Re: Mopar Ron] #166975
01/23/09 12:11 AM
01/23/09 12:11 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Its been awhile since we have had a thread showing our cars or projects. so heres where to post what ya got now
here is my squattie Truck and then my race truck project and my 42 COE(car hauler) then the radical,radical COE.
well thats enough from me
now show your cars and trucks.....
Squattie:
Racetruck:
42 COE(will be turned into a car hauler}:
Radical,Radical COE:
Ron, I don't care what anyone says, thats a cool truck
Re: Time to show your streetrods or rod projects [Re: Mopar Ron] #166976
01/24/09 09:47 AM
01/24/09 09:47 AM
My old-school 49 Wayfarer is low tech and pretty slow, but it does have some vintage speed equipment - Edmunds finned aluminum head and Offenhauser dual carb intake. Wide white walls and baby moons. Still 6 volt. One modern concession was front disc brakes after I had nothing but trouble with the original setup. Also replaced the fluid drive with a conventional manual clutch setup from a 55 Dodge.
Re: Time to show your streetrods or rod projects #166977
01/25/09 10:25 AM
01/25/09 10:25 AM
Iowa
Iowa
Ron is squattie, or the Radical Radical runing the original frames, I have done research on my '41 wd- 15(3/4 ton) its 5on 5 bolt pattern. though about boxing the frame, any thoughts
On the Gearz tv show/ trucks they took and box the frame, that is the look I am shooting for.
http://www.gearztv.com/?em2048=97441_-1_...3=&ek=97441
Re: Time to show your streetrods or rod projects [Re: 73ChargerSE440] #166978
01/25/09 11:44 AM
01/25/09 11:44 AM
Ron is squattie, or the Radical Radical runing the original frames, I have done research on my ' wd- 15(3/4 ton) its 5on 5 bolt pattern. though about boxing the frame, any thoughts
Squattie is on a 1989 dodge D50(mitubishi) chassis, it fit great, the back body mounts allmost lined up had to drill the holes in about 1" and the body mounts went right in
and radical,radical is on a early 90 toyota chassis for now but that may change
it depend on what you are doing with your truck and how you want it to look when done.
I like using later chassis on most of my stuff but a boxed stock frame work good too Ron...
Re: Time to show your streetrods or rod projects [Re: Mopar Ron] #166979
01/25/09 12:03 PM
01/25/09 12:03 PM
Iowa
Iowa
I have thought of the a 360 and the tranny from a Durango 9¼ Dana
Re: Time to show your streetrods or rod projects [Re: 73ChargerSE440] #166980
01/25/09 08:14 PM
01/25/09 08:14 PM
Monroe, LA USA
Carsavior Offline
Carsavior  Offline
Monroe, LA USA
Here's one that will probably not see a lot of progress real soon, but it is definately in line. 39 Dodge Cab and Chassis LOL-
Re: Time to show your streetrods or rod projects [Re: Carsavior] #166981
01/26/09 01:52 AM
01/26/09 01:52 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I started working on the 55 Desoto that I'm building for the G/Friend.
It needed the rockers and rear lower quarters welded up.
The plan is for it to be Purple and Silver, Her choice of colors.
It's getting a 318 Magnum and a 904 trans for the drive train.
She's going to be the one that does the interior.
She's into quilting and the upholstery thing is right up her alley.
She's helping with whatever she can, she wants to be able to say she helped build the car on it.
