Reproduction Hemi Engine harness #1669865
09/10/14 08:56 PM
09/10/14 08:56 PM
Iowa
ratroaster Offline OP
Iowa
Trying to figure out my best option for the Engine harness I need to buy for my Hemi. I want to run Electronic Ignition on it but the Ad on Year Ones website says that if your going to run an aftermarket Electronic Ignition you would be better off starting with the points style harness rather than buying the modified harness for the stock style Electronic Ignition. I want a stock appearing Electronic Ignition system with the best Performance . What are my options and which Harness should I get?
Re: Reproduction Hemi Engine harness [Re: ratroaster] #1669866
09/10/14 09:42 PM
09/10/14 09:42 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I did a 1970 Cuda with a Hemi a few years ago. Used the Yearone harness from M+H for electronic ignition. and it worked perfectly
Re: Reproduction Hemi Engine harness [Re: gtx6970] #1669867
09/11/14 01:22 AM
09/11/14 01:22 AM
chicago,il
jaque Offline
jaque  Offline
chicago,il
you come here with nothing and leave here with nothing!! enjoy life while on this planet, cuz when youre dead youre dead!!!
Re: Reproduction Hemi Engine harness [Re: ratroaster] #1669868
09/16/14 06:56 PM
09/16/14 06:56 PM
florida
rxod Offline
rxod  Offline
florida
I used Pertronix ignitor II system. Fits inside of distributor and uses stock harness. No box to hide. Works great.
Re: Reproduction Hemi Engine harness [Re: ratroaster] #1669869
09/17/14 01:04 PM
09/17/14 01:04 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
The YO harness is excellent. I have used the ones with the electronic setup built in like it was OEM and they work great. Really nice connectors and color coding on the wires are great. I have seen some people on here say Evans makes a good product as well.
I want my fair share
