Re: efi surge tanks?
[Re: Andrewh]
#1669634
09/10/14 01:12 PM
09/10/14 01:12 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Put a common electric pump between your tank and the surge tank. Move your current pump after the surge tank. Problem solved. As slow as your cars is (and how rarely you drive it) I don't think you'd have much of a concern anyway.
[Re: BlueGhost]
#1669637
09/10/14 02:30 PM
09/10/14 02:30 PM
Andrewh
Edelbrock makes one, it's been discussed a few times around here.
with the pump it makes it a little cheaper even than the radium one's.
but plastic bad enough to have an alumium fuel bomb in there. but melty plastic doesn't seem like a good idea at all.
[Re: jbc426]
#1669639
09/11/14 09:48 PM
09/11/14 09:48 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Personally, I'd just give up on the tank and go with the aeromotive phantom system. Seems like you'd have longer pump life and no more issues...and you should be able to hide it.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
