Re: Valve body with clean neutral
[Re: mopartony]
#1669609
09/10/14 11:26 AM
09/10/14 11:26 AM
Posts: 1,812 Portsmouth, VA
DusterW2
Portsmouth, VA
Be sure you know what you are getting and it matches your needs - Clean Neutral - Neutral position after 3rd that exhausts ALL bands and clutches http://www.gotranzact.com/valvebodies_page1.htmlThere is a clean neutral on moparts for sale right now - 72chrgrally - Mopar Transmissions for sale Sept section. "Trazact trans-brake valve body with clean neutral (PN123N pattern). Works perfectly." Safe Neutral - Neutral position after 3rd that exhausts ALL bands and clutches.. EXCEPT the direct drum. Keeps rotating components at same rpm as engine and prevents over speed of direct drum. More complex to build but SAFER. Griner only sells a "SAFE" neutral, P/N 1222G25B. TranzAct sells a "CLEAN" neutral as well as some other companies. http://www.727specialist.com/ , Hutch on Yellowbullet.com - http://hutchtrans.com/index.php?option=c...&Itemid=147John
[Re: mopartony]
#1669611
09/10/14 02:30 PM
09/10/14 02:30 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
IMO call the Smith clan at ProTrans..
[Re: mopartony]
#1669613
09/12/14 10:46 AM
09/12/14 10:46 AM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
Turbo action has a new line of VBs: "Turbo Action all new CHEETAH XtremeAction Valve Bodies will set a new standard of performance for race and the street. CHEETAH XtremeAction Valve Body, 17875XA has a safe clean neutral and no need to use a button to backup. A clean rear band apply and release making it a great race or street valve body and No roller clutch failure. Valve Bodies 17880XA CHEETAH XtremeAction Race Only and 17855EXA CHEETAH E-SHIFT have Clean Neutral and No Engine Braking Low Gear. New 17899XA TranzBrake Valve Body also available." http://www.turboaction.com/vbxa.htm#CHEETAH%20VALVE%20BODIES
[Re: Exit1965]
#1669614
09/12/14 11:37 AM
09/12/14 11:37 AM
Posts: 20,679 in a cattle trailer down by th...
Guitar Jones
It looks like the tranzbrake valvebody does not incorporate a clean/safe neutral.
[Re: Guitar Jones]
#1669615
09/12/14 12:06 PM
09/12/14 12:06 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
trans brake is on my list of santa presents ![](/ubbthreads/images/graemlins/biggrin.gif) thinking about that tranzact clean neutral reverse pattern valve body. Does it have low band apply would be my only question. I also like that PPP shifter, think it will be going on my santa list also ![](/ubbthreads/images/graemlins/biggrin.gif)
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
