Re: Time to show your streetrods or rod projects
[Re: Mopar Ron]
#166963
12/15/08 10:25 PM
12/15/08 10:25 PM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Chopped and sectioned!I thought it had a low profile compared to others I've seen.I myself have a coe,but it's not rod material,it's a '69 Dodge L-600 tilt-cab.Hope to make it a car hauler for my A-100 van Ron yes, it's chopped 3 1/2" and its sectioned 4" it was going to be my radical toy but now its going to be my radical car hauler and the other COE is going to be the toy with the blown 440 thats why I call "IT" radical,radical COE. Ron... this is another shot of radical,radical. its sets much lower than the first one
[Re: leavitt4]
#166966
12/21/08 12:22 PM
12/21/08 12:22 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
Hey Ron more pics of the radical radical ?
Adam
67 Ply. Belvedere II 2dr Hardtop
73 Dodge Charger SE 440+6 727 Dana 60 4.10
78 Chrysler Cordoba 400-4 727 9 1/4 3.21
1999 Dodge Diesel 2500 QuadCab Longbox
2004 Dodge Durango HEMI Limited
[Re: RTSrunner]
#166968
12/25/08 07:05 PM
12/25/08 07:05 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Ron, when you made he front fender inserts to make them smaller, what kind of a lip did you use, flat or rolled?
[Re: rowin4]
#166970
12/26/08 01:46 AM
12/26/08 01:46 AM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
my neighbor was making a baja bug and he cut up the rear fenders on a VW bug so I took the rolled lip and welded them to the coe front fenders Ron...
[Re: Mopar Ron]
#166971
12/26/08 11:40 AM
12/26/08 11:40 AM
Posts: 228 Kentucky
Flipper1938
Kentucky
Damn! I guessed right!
The trailing side looked really VW to me.
[Re: DusterKrazy]
#166973
01/07/09 06:29 PM
01/07/09 06:29 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
Hey DusterKrazy, is that a front clip from a duster on the front of the frame?
I have a 41 not sure what drivetrain/running gear I am going to use
Adam
[Re: 73ChargerSE440]
#166974
01/07/09 07:54 PM
01/07/09 07:54 PM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
Adam
Actually it's the frame from a 1977 dodge d100 pickup that we cut 2ft. out of This seems to be not a bad route to go as the late 70's dodge trucks are still cheap if you look around for them. Engine mounts are easy as well, already in place and the brake parts are reasonable as well. Good luck with your project!
The cab seems a little wide at first but once we fab up the mounts and get it channeled it will look just right
[Re: Mopar Ron]
#166975
01/23/09 01:11 AM
01/23/09 01:11 AM
Posts: 16,141 Mesa, Arizona
dart4forte
Mesa, Arizona
Its been awhile since we have had a thread showing our cars or projects. so heres where to post what ya got now
here is my squattie Truck and then my race truck project and my 42 COE(car hauler) then the radical,radical COE. well thats enough from me
now show your cars and trucks.....
Squattie:
Racetruck:
42 COE(will be turned into a car hauler}:
Radical,Radical COE:
Ron, I don't care what anyone says, thats a cool truck
[Re: Mopar Ron]
#166976
01/24/09 10:47 AM
01/24/09 10:47 AM
#166977
01/25/09 11:25 AM
01/25/09 11:25 AM
Posts: 451 Iowa
73ChargerSE440
Iowa
Ron is squattie, or the Radical Radical runing the original frames, I have done research on my '41 wd- 15(3/4 ton) its 5on 5 bolt pattern. though about boxing the frame, any thoughts On the Gearz tv show/ trucks they took and box the frame, that is the look I am shooting for. http://www.gearztv.com/?em2048=97441_-1_...3=&ek=97441
#166978
01/25/09 12:44 PM
01/25/09 12:44 PM
Mopar Ron
Ron is squattie, or the Radical Radical runing the original frames, I have done research on my ' wd- 15(3/4 ton) its 5on 5 bolt pattern. though about boxing the frame, any thoughts
Squattie is on a 1989 dodge D50(mitubishi) chassis, it fit great, the back body mounts allmost lined up had to drill the holes in about 1" and the body mounts went right in
and radical,radical is on a early 90 toyota chassis for now but that may change
it depend on what you are doing with your truck and how you want it to look when done.
I like using later chassis on most of my stuff but a boxed stock frame work good too Ron...
[Re: Mopar Ron]
#166979
01/25/09 01:03 PM
01/25/09 01:03 PM
Posts: 451 Iowa
73ChargerSE440
Iowa
I have thought of the a 360 and the tranny from a Durango 9¼ Dana
[Re: Carsavior]
#166981
01/26/09 02:52 AM
01/26/09 02:52 AM
Posts: 10,132 A Red State
SNK-EYZ
A Red State
I started working on the 55 Desoto that I'm building for the G/Friend. It needed the rockers and rear lower quarters welded up. The plan is for it to be Purple and Silver, Her choice of colors. It's getting a 318 Magnum and a 904 trans for the drive train. She's going to be the one that does the interior. She's into quilting and the upholstery thing is right up her alley. She's helping with whatever she can, she wants to be able to say she helped build the car on it.
