Head gaskets for Procharged big block? #1669031
09/08/14 04:23 PM
09/08/14 04:23 PM
Shannonville, Ont
Blown 68 R/T Offline OP
Shannonville, Ont
Was wondering what everyone is using. Used Milodon solid copper for several yrs now need to change after blew one yesterday at the track.Was looking at ICS Titan,Cometics & Fel pro MLS. So what are you guys using?
Re: Head gaskets for Procharged big block? [Re: Blown 68 R/T] #1669032
09/08/14 06:03 PM
09/08/14 06:03 PM
Az
Crizila Offline
Crizila  Offline
Az
I run Cometics - 21 lb boost with no problems so far.
Fastest 300
Re: Head gaskets for Procharged big block? [Re: Crizila] #1669033
09/08/14 07:11 PM
09/08/14 07:11 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
Cometics here as well. Only ran 10-11 PSI, but they usually seem to be the choice with boost and nitrous motors.
Re: Head gaskets for Procharged big block? [Re: Charger453] #1669034
09/08/14 08:10 PM
09/08/14 08:10 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
Cometics here also, small block 25 lbs of boost. Head gaskets looked good when it was pulled apart. Only a 2 passes full passes and a couple partial passes at 25 lbs
Re: Head gaskets for Procharged big block? [Re: Blown 68 R/T] #1669035
09/09/14 12:11 AM
09/09/14 12:11 AM
ICS copper Titans with receiver grooves I've used them on Roots blown hemi with 22 lbs of boost on race gas, no problems ever
