Rearend lube and additive #1668825
09/08/14 10:29 AM
09/08/14 10:29 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I recently picked up a rusty 94 Ram 2500 HD 4X4 gasser. I want to change the Differential fluid in both axles.
What brand fluid and friction additve do you guys recommend.
Use a gasket or sealer?
Thanks,
Re: Rearend lube and additive [Re: nd65] #1668826
09/09/14 12:08 AM
09/09/14 12:08 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I would use sealant, name brand synthetic 75-90 front and 75-140 rear. Two bottles of ford ls additive.
Re: Rearend lube and additive [Re: NITROUSN] #1668827
09/09/14 10:16 AM
09/09/14 10:16 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Thanks!!
Re: Rearend lube and additive [Re: nd65] #1668828
09/11/14 10:55 PM
09/11/14 10:55 PM
In the Middle
roadntrack Offline
roadntrack  Offline
In the Middle
Why Ford additive?
Remember when cars were FUN?
Re: Rearend lube and additive [Re: roadntrack] #1668829
09/11/14 11:14 PM
09/11/14 11:14 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Why Ford additive?
I have found it to work as good as any other and to have a better price.
Re: Rearend lube and additive [Re: NITROUSN] #1668830
09/12/14 12:20 AM
09/12/14 12:20 AM
IN
ahy Offline
ahy  Offline
IN
Black RTV is commonly used in place of the gasket on rears. Your choice. If you use the gasket + RTV do not torque the bolts until the RTV is set up.. a couple of hours. Otherwise the gasket may split and squeeze out. Either way, clean well first (razor or putty knife + lacquer thinner or brakeclean).
For the lube... with general use I believe any 80W90 lube will work fine. If the rear is limited slip, a tube of additive is needed. Two tubes? Maybe for a big PU rear but suggest one tube first and add another if it chatters.
If you are towing hard, heavy and fast, 75W140 synthetic will provide more protection for high temp situations.
Re: Rearend lube and additive [Re: ahy] #1668831
09/12/14 08:17 PM
09/12/14 08:17 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I am gonna use black rtv w/no gasket.
Thanks guys.
Re: Rearend lube and additive [Re: nd65] #1668832
09/14/14 11:53 AM
09/14/14 11:53 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Use the Permatex grey sealant RTV...it's for use with gear lube.
Nautilus Racing-
Re: Rearend lube and additive [Re: Chris2581] #1668833
09/16/14 11:51 PM
09/16/14 11:51 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Use mopar axle sealant orange or gray. No set up time required just put it on and bolt it up. For years the black was ATF sealant for the cars. Although they recently change so read the tube.
Re: Rearend lube and additive [Re: Chris2581] #1668834
09/17/14 01:02 AM
09/17/14 01:02 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
BINGO! I run 75/140 syn out here in the desert.
